*#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though. (type this on the main screen)
hope yougot the solution.
SOURCE: no network coverage sony ericsson k800i
my phone sonyericsson w800i sim card accept the phone and display the network airtel, hutch ect. but call from other phone disappear the tower
SOURCE: my sony ericsson k800i phone has a problem with signals
hello
the problem is with your phone's hardware
SOURCE: my sony ericsson w595 does'nt
from the specifications you have provided it is clear that you are having both software as well as a hardware problem .first of all go for a software update of your phone. then go for a hardware check up. probably your phone is unable to recognise its own battery.
The phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
