I have a fridge/freezer Active Smart the fuse popped and power to fridge was off when the fuse was put back on the fridge wouldn't go tried another plug and nothing happening
either a shorted out relay which is connectrd to the side of the compressor or wirings inside the compressor have shorted out ,relay is easy to check its under a plastic box cover on the sideof the compressor,pull it off and have a look for any burn marks or smell even shake it to see if it sounds all broken up inside is only a small unit if good then its time for a new fridge
1.Check the power cable for intactness.Use a multimeter or simple Tester screw driver to check whether the supply is reaching the distribution box.(if this is the problem ,replace it)
2.if there is any humming in the compressor then there is chance for piston strucking.The solution will available at service centre only.
3.Check the Defrost switch and make sure that it is not pressed .If the switch is not coming back to previous position then try with a gentle pull and wait a short to automatically close the switch.If it is not still working then contact a service personal or if u r an expert with thermal switch u can open it .(before opening any panels or circuit boxes you must unplug the device from the power.otherwise serious shock injury will happen.
Check fan in the freezer
Also check auto defrost (ice on the freezer coils anot allowing
air to the fridge.)
If so go to appliance parts store to learn the parts to fix auto defrost.
If this was helpful please rate me. Leo Ponder Appliance-Tyler,Texas [email protected]
press the select button ( the button that you choose the temperature on the fridge and freezer) and check that the fan on both fridge and freezer are working.
My fridge (E440T but I believe the E522B is similar) had a broken fan wire and i had to pull off the rear panel and re-solder a wire. I created a document for others to follow that shows the rear panel removal if interested at http://www.accentis.com.au/downloads/misc/How I fixed my Fisher and Paykel Fridge Active Smart Fridge.pdf
Thanks to all postings on this site - it really helped a lot.
Is there a little fan back there with the compressor? if so is it turning? also check the outside coil, it may be covered with dust & crap. Sometimes that is all thet it takes. A good cleaning.
