SOURCE: bosch 3000 dishwasher
Don't. Just attach your hose and the end of the Bosch hose together. Just wind up the Bosch hose and tape it to the back of the machine.
SOURCE: There are two hoses coming
The air venting hose must not necessarily be connected to anything. What else is wrong with the appliance?
SOURCE: NEED THE OPERATORS MANUAL FOR BOSCH SHX45M05UC
I was looking for the same manual and I found it here:
http://kitchen.manualsonline.com/manuals/mfg/bosch/shx45m.html
Hope this helps!
L.J.
SOURCE: Bosch SHU3306UC dishwasher is slowly filling with
If water continues to enter the dishwasher when the power is off at the breaker, you most likely need to replace the water inlet valve/solenoid assembly. The valve is not closing fully allowing water to seep into the washer when not in use. Water should not enter the dishwasher via the drain hose as there is a non-return valve to prevent this happening.
If you have a check valve for the water supply to the dishwasher, close the check valve. If the washer does not fill with water with this valve closed, you definitely need to replace the inlet valve. The inlet valve/solenoid is located behind the toe-kick below the door and is relatively easy to replace yourself. The only tools required are a Torx T20 screwdriver (for removing the toe-kick and the valve) and a pair of pliers.
If you are confident that you can undertake this repair yourself and have the tools, please let me know and I will provide part/supplier details and fitting instructions. If you would prefer to call a professional, the part costs about $30-35 and you should not be charged more than an hour for labor.
Hope this helps. You can reply to me by clicking on "Add a Comment" below your question.
Regards,
BElectric.
I have the same problem with this hose, FRW-10967. It seems to lead nowhere, is it somekind of vent?
