Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
Posted on Mar 14, 2008
Wd640 hotpoint washer dryer - error code F03
The machine is showing an error code of F03 and will only let you turn it off by switching it off at the mains - any ideas PLEASE
Anonymous
Level 1:
  • Contributor 16 Answers
  • Posted on Mar 16, 2008
Anonymous
Contributor
Level 1:
Answers
16
Questions
Helped
10153
Points
63
This indicates that the wash thermistor is "Open Circuit" and I think it is situated on the heater assy at the back of the machine.
Check the wiring and contacts between the thermistor and the PCB. If you still get the fault it could be the Thermistor ( which means replacing the heater ) or a faulty board.
If it is under 5 years old - Call Hotpoint as you have a 5 years Parts Guarantee mind you the call out is £89.98 but thats cheap if it happens to be the board!
F-03 ON HOTPOINT MODEL WD640
F03 - Wash thermistor open/short circuit*
My machine is a WD640 washer/dryer and is displaying in the led display F-01 ? The machine will also not fill with water but the countdown on the cycles are working
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} F01 on a Washer Dryer means you have a motor fault. Check the motor and associated wiring. You may just have a broken wire. Click on the link for more Hotpoint, Creda and Indesit error codes. Or use these links for WMA & WM workshop manuals.
1helpful
My hotpoint WD640G has stopped mid cycale and is showing the code? F O5 and will not complete the cycle
Error code F05 denotes pressure switch jammed on full.
Remove the lower rear panel of washer.
Remove the large black hose on bottom of drum.
Remove and clean filter inside hose.
Refit and test.
Please rate my solution.
Thankyou.
2helpful
Wd640 problem not pumping out f-05
Error code means pressure switch jammed on full.
Remove lower rear panel of washer
Remove large black hose fastened to bottom of drum
Remove hose on to pump and check for blockage or obstruction here as well
Thankyou.
Hotpoint washing machine, model WF630, Error F-03???
Error code F03 is indicating a problem with the wash thermistor, it could be open or short circuit.
Check connections on thermistor and heater element.
Hope this helps.
3helpful
F13 error during drying cycle
Hi, that indicates that either the fan motor is not working/ blocked or the dryer thermistor (thermostatic sensor) is playing up. Of course, the pcb reads the sensor so it could also be that causing the error.
2helpful
Error code f-01 on hotpoint washer dryer aquarius model wd 640
f-01 means there is a motor problem.
may be the motor and/or the circuit board that controls it.
Error code f 18 on hotpoint wd640 ? any idea Everything seems to be working except drium isn ot turning, i hace checked the obvious like the belt.
F18 usually indicates a communication error according to Hotpoints error code list, if you have tried everything that you can and it still does not work, then you are going to have to call an engineer.
Hot point aquarius wf740
Hi.
F03 indicates that the wash thermistor is open or short circuit.
I think you need to call engineer to sort the problem
Please leave feedback.
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
