for more clear instructions go here
http://www.motorola.com/mdirect/manuals/QG-H300_9495A08A.pdf
With the headset power off, press and hold
the Call button for 6 to 10 seconds until the
blue indicator light turns on and remains
steadily lit. (The light will flash while you
hold the Call button.)
If the indicator light is flashing or does not
remain steadily lit, turn off the headset and
repeat step 1.
Before you can use your headset, you must
pair (link) it with your phone.
Step A - PUT HEADSET IN PAIRING MODE
Note: To turn off headset, see "Turning On and Off" on the
reverse side of this guide.
PAIR
Your Phone
Select (Menu) > Settings > Connection >
Bluetooth Link > Handsfree > Look for Devices.
The phone lists all Bluetooth devices it finds.
Select
Motorola H300.
Press
OK or
Yes to pair (link) the handsfree
device.
Enter the passkey
0000 and press
OK.
Note: Passkey cannot be changed
from 0000.
Step B - SET THE PHONE TO LOOK FOR
YOUR HEADSET
When your headset is successfully paired
