It would stop freezing and the alarm would come on. After pressing the express freeze button it would start freezing again. After about 11 hours after this freezing began the alarm would come back on again. This has been the cycle for months now. After these months it will stop this cycle and go into a normal freeze defrost cycle. This normalcy will last for about 1year at which time the problem starts all over again. What is causing this to happen ?
Warning light (red)
If the temperature warning light (4) lights up, it
indicates that the temperature within the freezer has
reached a level where the safe food storage is no
longer ensured. When the freezer is first switched on, the warning light will stay on until the temperature has dropped to
a safe level for the storage of frozen food.
Temperature acoustic alarm
This appliance incorporates an alarm which gives off
an audible signal whenever the warning light comes
on. This signal can be temporarily stopped by
depressing the push button for fast-freezing (6).
The fast-freezing push button can be released as
soon as the warning light is off.
Open door acoustic alarm
This appliance also incorporates an alarm which
sounds if the door is left open for more than 60
seconds. The signal will be stopped when the door is
closed again.
Can't be specific without seeing it. All alarms I have ever seen have adjustable set points and differentials. It looks like a commercial box? Look the controls over real well and you should find it. You may need to remove a cover for access.
Red Alarm Indicator Light
Under normal operating conditions, the internal temperature of the freezer will ensure the long-term conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once.
When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food.
Fast Freeze function
If more than 3-4 kg of food is to be frozen:
1. Press the Fast Freeze Switch for 2-3 seconds to activate the fast-freeze function 6-24 hours before placing the fresh food in the freezer, the Yellow Fast Freeze Indicator Light will illuminate. The compressor will now run continuously, to ensure that the fresh food is frozen as quickly as possible.
2. It is possible to deactivate the function at any time by pressing the Fast Freeze Switch for 2-3 seconds.
3. Place the foods in the freezing compartments (indicated with graphics).
4. Once the food is completely frozen (it may take up to 24 hours) you can manually switch off the fastfreeze function by pressing the Fast Freeze Switch for 2- 3 seconds and the Yellow Fast Freeze Indicator light will also go out.
5. Move frozen food from the freezing compartments into the other compartments (storing compartments) to make room for another freezing.
If the Fast Freeze Switch is accidentally left on, the fast-freeze function will be automatically switched off 48 hours later. The Yellow Fast Freeze Indicator light will also go out.
I believe that you all understand. If you intend to freeze larger amount of food then certainly a few hours before some shopping switch on the fast freeze function.
Unplug it for about 10 minutes to allow any capacitors to dissipate. Switch back on. If alarm starts straight away, suspect faulty controller, probably caused by the spike in the power supply
I turned the fridge and freezer off using the circular dials, I then turned the unit off at the mains. Left it for a few minutes and then turned the power back on. I then turned the circular dials to "max" and then depressed the super cool and super freeze buttons to turn this facility on. This time they came on normally (not flashing) and no alarm sounded. The fridge and freezer then started to get cold. Once the unit had been running for several hours I then turned the dials to the 3/4 mark and depressed the super cool and super freeze buttons again to turn them off. Over night the fridge and the freezer appear to be working properly so I hope that my problem is solved. Maybe the unit just needed to "settle" before being switched on?
