Hi Lawrence.
There should be a few more numbers/ letters to your model number. I added a link to a website for you to check out. Click the link or copy and paste it. Hope this helps.
Charge battery to 12.8 volts or higher. 13.2 best. Below 12.8 volts replace battery. USE FRESH GAS ONLY. Always use Stabile in gas. Ensure oil is full. 30w. Clean or replace air filter.
Is the engine installed on a mower? If not, do you have a good ground connection? If so, try using a jumper cable to go from the positive on the battery to the terminal on the engine starter. If starter good and no other mechanical problems (i.e. broken connection rod), it should turn.
From your description it seems that the starter is not engaging to turn over the engine. First ensure all the connections of the thicker cables to the battery, starter and tractor frame are clean and tight. If starter motor is turning but still not engaging it will mean that the pinion on the starter motor is binding on the shaft. You can buy a new starter pinion gear from your local B & S agent.
To replace pinion, remove starter motor from engine, remove old pinion and put on new one and reattach starter to engine. If fuel & spark are right you should be up amd running.
