Question about Razor E100 Electric Scooter
When I plug in the charger is shows green, but the scooter does not run. Should I replace the battery or the charger? E100 razor.
  • Anonymous Mar 24, 2014
    Charger for razor scooter Pocket Mod can I just take the wires loose you home to Jack and white straight to the battery and plug the charger in the jack and your charger straight like a regular battery charger
  • 5 Answers
Check the voltage output of the charger. It should be about 28 volts. Most likely your batteries are dead (over 2 years old?)
Posted on Apr 11, 2010
  • rasmo00o7 Apr 10, 2011
    Thank you for the info :))
Scooter is less then 6 months old. The charger says it has a full charge, but the power switch light on the scooter itself is not working.
Posted on May 01, 2011
  • 4 Answers
Yes, probably the batteries have come to the end of their useful life. Age of batteries is one indicator that helps in diagnosis.
The following refers to Sealed Lead Acid batteries:
Most important is the question how have the batteries been treated in those 6 months?
• Was an intelligent battery charger used that helps keep the batteries from getting hot during charge cycles and shuts off when it senses the batteries are fully charged?
• Were the batteries charged frequently & immediately, especially after prolonged usage that runs the battery down?
•Were the batteries allowed to cool for an hour or more before charging? Heat will damage batteries and it is helpful (although impractical) to try and keep batteries cool by taking breaks during use.
•Was the battery pack left in a discharged state for an extended period of time? Batteries can also go bad if left idle for a long period of time; sediments shall collect at the bottom of the battery shorting out the lead plates inside.
•Was the charger left on to keep charging the batteries, even after they were fully charged? Over-charging reduces life span.
•Batteries store & work best in the 70 degree range. Any deviation induces less efficiency, until storage in extremes, either high or low (freezing), can cause premature failure.
So if yours are Sealed Lead Acid batteries, & they were subject to any one or more of the above conditions, it\'s not unreasonable to assume that they should be replaced.
Batteries last between about 50 & 200 charge cycles, depending on how they were stored, used & treated/maintained.
I bought my batteries in April & ignored them until October. Now I am taking good care of them. I am documenting usage to determine how badly I damaged them as a result of neglect. I feel certain that I shall get reduced usage as a result of the neglect.
Learn from the error of my ways!
Posted on Oct 02, 2014
    New Friend:
The charger is fine most likely you need to replace the battery
Posted on May 24, 2013
SOURCE:
Batterys showing full charge but when my daughter gets on in power kicks in then stops
razor hasnt been charged for a week as i needed a new charger i had 1 scooter charging over night yet still nothing , i bought a new charger its showing green on the light do i have to wait till it shows red and then wot if it doesnt still work
Dec 17, 2013 | Razor E100 Electric Scooter
Have an e100 razor electric scooter. it has not been used since I bought for a couple of years. I got a new e100 charger and tried to charge but I noticed that the charger's does not activate either red...
Most equipment running on rechargeable batteries have one thing in common: if you let the battery sit there for long periods of time without recharging, the charger is not made to bring the battery back up to spec. The battery pack, if it is still good, needs a "kick" or "boost" from some other strong supply to get it started.
The other solution would be to replace the battery pack all together. If you have a friend with a similar scooter, you can try your new charger on his scooter to see if it works. Hope this helps!
Oct 21, 2013 | Razor E100 Electric Scooter
I have had my e100 electric scooter for a about 2 years i havent actually used the scooter in 12 months so today i plugging in into the wall with the charger and there is a green nonflashing lite on the...
The charger light should normally be red if the battery is accepting a charge and green when the charger goes into trickle charge or off. SLA batteries do not last well if they are not regularly given a top up charge. I suspect the battery needs replacing.
If you have access to a voltmeter then you can test the battery voltage at the charger input port on the scooter.
There are lots of places that sell Razor E100 scooter parts and provide resources/information on replacing the battery.
Here are a few: http://www.razorama.com/
http://www.scooterguru.com.au/
http://electricscooterparts.com/
http://www.monsterscooterparts.com/
Jul 30, 2013 | Health & Beauty
How long does it take to charge Razor E100 Electric Scooter - Red
You threw away a perfect scooter you idi0t. Needed to desulfate battery with a smart charger. M0ron.
Sep 14, 2012 | Razor E100 Electric Scooter
My charger light shows always green and it does not charge the scooter.
Usually that means the battery is not able to hold a charge.
Jul 29, 2012 | Razor E100 Electric Scooter
When i plug the charger in the light stays green yet the scooter is not charged
I had the same problem i replaced the battery and still nothing. Found that the charger was bad and reading that the battery was charges. Replace the charger. You can get them online fairly cheap
Jan 23, 2011 | Razor E100 Electric Scooter
Wont charge tryed a new charger think its the battery can i replace the battery ?
Razor E100 batteries are easily replaced & there are guides on how to this on razor.com, genuine Razor batteries are available at most good Razor product stockists.
Dec 30, 2010 | Razor E100 Electric Scooters Red
Have an e100 razor electric scooter. it has not been used for a couple of years. I got a new e100 charger and tried to charge but i noticed that the green light stays on and the red light charging does not...
The batteries are dead. The battery in these scooter need to be kept charged or if not in use for a long time charged every 3months. Otherwise, like what to you, they will go dead. The chemicals in the battery have deteriorated to the point where it won't hold a charge. Replacement batteies are available at:
razor.com
Jul 20, 2010 | Razor E100 Electric Scooter
Razor E100 reset button and no charge
Hi... My son hasnt used his Razor E100 for nearly a year as couldnt find the charger.. I finally found it and as soon as I plugged it in the plug was showing green light as that it was fully charged... When we turn the unit on it lights up but its dead... Where can I get the cheapest battery (and does it have 1 or 2)? Or you mention a reset button? Many Thanks...
Jan 24, 2010 | Razor E100 Electric Scooter
Razor E100 Electric Scooter Logo
5,390 people viewed this question
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
William Erickson
Are you a Razor Toy Expert? Answer questions, earn points and help others
