Yard Machines 24a 452g729 5.5 Hp Chipper Shredder Logo
Posted on Mar 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to pull the impeller assembly from a Craftsman 247-776360
Need to pull the whole assembly from my Craftsman chipper/shredder (7.5 HP). Do I have to simply force it off of the shaft? Or is there another way. The shredder blade has been removed.
Derrick Schultz
Level 3:
Top Expert:
  • Yard Machines Master 11,405 Answers
  • Posted on Jan 21, 2019
Derrick Schultz
Level 3:
Top Expert:
Answers
11405
Questions
0
Helped
2326816
Points
23972
Some fixya user told me a website reliablestore it is very good.. I used it to repair my shredder it had some spark issue which wasn't easily fixed. you can go there and try
most shredder owners know about it
it's free so no harm in trying
5 Related Answers
Anonymous
  • 163 Answers
  • Posted on Nov 30, 2008
SOURCE: Craftsman Chipper-Shredder Model No. 247.775870
If a small engine wont start its usually one of two problems, its not getting gas, or its not getting spark. easy way to find out if its getting a spark is to remove the plug, put it back back in the connector and just let it hang down while you try to start it. you should see a bright blue spark, if you dont try changing the spark plug. if its getting a spark come back on this site and i'll help you trouble shoot it.
donald boissonneault
  • 110 Answers
  • Posted on Mar 19, 2009
SOURCE: 9hhp craftsman chipper shredder won't start
Squirt a couple of spoonfuls of oil into the spark plug hole to increase the compression as it has been sitting so long. Also squirt a little starting fluid into the carb. and give it a shot I think it will start. Hope this will. donnyb60
vincob
vince janis
  • 718 Answers
  • Posted on Oct 09, 2009
SOURCE: I have a yard machinne 6.5hp chipper/shredder -
The blade(s) should have usually two bolts on them depending how many blades you have. Mine only has one blade held on with two bolts and that is only on the side that cuts the larger branches up to two inches in diameter and should be sharpened on a grinding wheel because it has a specific angle to it. The other side that chips smaller branches and twigs it a type of flailer, meaning pieces of metal just swinging around to mash up the sticks and do not need sharpening.
rwvanlue
Roland W VanLue
  • 486 Answers
  • Posted on Nov 08, 2009
SOURCE: How to sharpen blades on a Yard Machine 6.5 chipper
http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=10151
above link will provide a pdf of manual
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Anonymous
  • 411 Answers
  • Posted on Feb 25, 2011
SOURCE: I have the small electric chipper shredder and
In your browser type in http://www.mtdparts.com/webapp/wcs/stores/servlet/Home_10101_19502_-1?cm_mmc=MSN-_-MTD-_-Yard%20Machines%20Parts-_-Sponsored
Testimonial: "THANKS"
Where can I get a manual for a Craftsman 8HP Chipper Shredder Model Number 987.799840.
https://search.yahoo.com/search?fr=mcafee&type=E210US1494G0&p=craftman+8+hp+schredder+serial+987.799840+manual
Finding a bag for chipper shredder model number 247-799630
Hello, Jay -
Is your chipper / shredder a Craftsman make? If so, see:
https://weingartz.com/assembly-diagram/mtd-parts-lookup/model-247-333c099-247-799630-1997-nozzle-bag/4374-289144-430448
Part # 764-0484
According to other information I have found, the collector bag is no longer available / no longer made. See:
https://www.partstree.com/parts/mtd/chippers-shredders/247-799630-247-333c099-craftsman-shredder-vacuum-1997-sears/nozzle-bag/
Part # MTD 764-0484
Best wishes.
Why won't the pull cord budge?
My first idea is that the engine was shut off before the chipper or the shredder had not finished. First remove the spark plug. Next remove the covers on the chipper area and the shredder area. Now remove all material from both areas.Replace all covers, put the sparkplug back and try it.
Replacing engine
all instructions about these are available on manuals that
I keep getting those for my vehicles too.. I know a lot of websites and which one is best for what type of vehicle.
How to remove impeller assembly from troy bilt shredder model 414?
try pb blaster soke 2 days our more and when you get it off clean up shaft make sure the impeller slides free on shaft then put anti seize on the shaft like troy built should have done
if you can use puller on it if not then air hammer about 20.00 at harbor fright home depot lowes if you have air tank
10helpful
2answers
How to remove impeller assembly from chipper
You can download a PDF2.gif manual for your chipper at ( www3.sears.com ) Type your model number like this ( 247.795890 ) It will show you a parts list for it and also there will be a place that says "Manuals" click on that and it will download to your computer2.gif where you can either save it or print it out or both
Need set of 4 impeller vanes for Troybilt chipper model 47261
You can get the impeller parts at:
http://www.thefind.com/garden/browse-troy-bilt-chipper-vac-parts
Good luck,.,
I just purchased a used 47261 yesterday for $200 .. It is like new, but I may need a new bag from this site and I will need to find a manual somewhere.
MrBill
1helpful
Top Yard Machines Heavy Machinery Experts
ADMIN Andrew
ADMIN Andrew
Dmitry Isayev
Dmitry Isayev
Are you a Yard Machines Heavy Machinery Expert? Answer questions, earn points and help others
