2H is not exactly an "error code", but it does indicate a problem. It means that the machine exceded its wash time by more than 2 hours. This is usualy caused by a failure of the heater, most often caused by a failure of the controll. Remove the control from the door, remove the plastic housing from the control, and check for a bad solder joint on the heater relay.
If you find a bad solder joint, REPLACE the controll.
Or call a qualified service person.
NOTE: The SHU53A dish washer with serial numbers from FD8205 to FD8507 are included in a factory recall. If your dishwasher is one of these contact BSH @ 1-800-586-9226 24/7.
