You could try resetting the computer. The car maybe in lockout mode. Try turning your car over….leave the ignition on. Wait exactly 10 min. Then try turning over again….again leave the key on. Wait exactly 10 min and do it a third time….this time the car should start…maybe run a lil rough while it relearns the processes of your vehicle again. It is important to wait the exact 10 min each time. You will probably need a battery charger or a set of jumper cables because if your car goes low during this process it will not work. Good luck and I hope this works.
