I just started getting the SUDS error code today. The manual says it will drain on its own automatically but it ran for over 2 hours with the code, so I just had it do spin only since there are no suds at all in the washer. Each time I try to wash again, this code comes up halfway through the load. I use less than the recommended amount of HE detergent, so I know there is no backup from non HE use. Any ideas of what I can do?
What does the Sd code mean?
This code indicates that excessive detergent suds occurred during the cycle. The washer will not be able to spin out water with the excess suds. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the wash action and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This process is necessary and may occur several times to eliminate the suds.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
Use only HE High Efficiency detergent for BravosTM washers.
Is "Sd" displayed and the wash cycle dial is flashing? This indicates the washer was not able to clear all the excess suds from the washer. Re-select your desired cycle using cold water. Press Start/Pause. Do not add detergent. Is "Sd" displayed and the wash cycle dial is not flashing? If "Sd" is displayed and the wash cycle dial is not flashing, allow the machine to continue running, even if it appears that nothing is happening. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the wash action will pause to allow the bubbles in the suds to break, and the washer will add water for better rinsing. This rinsing process is necessary and may occur several times to eliminate the suds. Is the drain hose kinked or clogged? Make sure that the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose. To remove the error display, press Power/Cancel or Pause/Cancel once.
If Power/Cancel or Pause/Cancel does not work: NOTE: If the error remains on the display, and all of the other questions above have been checked, call for service.
Nope, did not work at all. Had someone from maytag come out and they unplugged it and plugged it back in and suggested I do a few loads with cold water and salt. all it does is run through the "suds" cycle for hours at a time. Does anyone have any helpful advice? I don't want to keep paying for people that do not fix a darn thing.
I tried to put it through again without soap, same thing happened again, SEVERAL times. The only thing I have been able to do is just turn the power off then start it up again on the spin only cycle and get it out of there! It seems to do this more frequently now and of course it is just off warranty. There has to be something wrong here. I don't use a high sudsing soap and I don't use very much. It doesn't happen only when I wash towels.
SUDS error all the time now, was only on occasion. Use the rinse and spin and it will end cycle but so much for the Low water High Efficiency washer. Any solution would be appreciated.
I am having the same exact problem. Even took to a repairman. Have you found the solution. It gets worse and want spin or rinse clothes. My clothes are sour smelling because soap is still in the
