Dear
th model and make information could do better. However PAPER button blinks indicate there may be paper jam or dislocation of paper sensor lever, sometimes it happens if the paper pulled in reverse direction a small piece of paper get sticked at the sensor lever and latched the lever, on clearing this printer may resumed.
Thanks.
Same thing happened to my printer hp L7590. Printed diagnostic, only black and yellow printed; diagnostic for printhead health Ky=good, MC= good. Only Hp products ever used. Uplugged, & discharged static, cleaned copper parts of printhead. Still no fix. On visual examination of floor of printhead compartment rectangular pad ( approx 1/4" by 1/2") is missing. I can only guess that during the paper jam, somehow the pad got caught up and went awol. Not sure what to do now.
first thing you need to do is will do the overriding the error
1. open the pritner access door fo the printer 2. if the printhead or ink cartirdges already in center remove the ink cartridges and the printhead 3. If the printhead already removed close printer access door., Turn Off the pritner then after 10sex turn It own.
4. Now your pritner should detect no printhead installed not paper Jam., If you still recieved paper jam error without the pritnhead installed you need to have a printer replacement call kodak toll free number 1 800 421 6699 ext 05
5. Now if the message is pritnhead not installed., reseat the printhead and the ink cartordges then close the pritner access door., If your ecived same message paper jam., You need to replace the printhead you may also call kodak 1 800 421 6699, and have your free printhead replacement.
Most of the time overriding the error message solve the problem
A friend uses methyl alcohol to clean printheads but I don't know how. Perhaps he fills an empty cartridge...
I watched a guy professionally filling cartridges and he used steam to clean those with a printhead.
Printers that have the printheads in assembly instead of integrated into the cartridge can be difficult. Epson are like that and if not in regular use and always with a good supply of ink the printheads dry out and become blocked. The Epson service engineer told me it would be completely uneconomic to dismantle the printer and repair.
I expect it is a similar story with many printers that make a cheap ink claim. Cartridges that have the integral printhead are more expensive but seem less trouble overall.
Error Condition
Indicator
Beeps
Error Code
Possible Solution
Paper Feed / Delivery
Orange
Remove any paper jammed
Paper Jam
Orange
Ink Out
Orange
Add Ink
BJ Cartridge Misinstalled
Orange
5
Re-install cartridge or replace it
NO BJ Cartridge
Orange
6
BJ Cartridge Error
Orange
7
Waste Full warning
Orange
8
Waste is almost full , needs service very soon
Service ErrorsBlinksBeepsError CodePossible Solution
ROM Error
1 x Orange
10
6100
Try unplugging Printer
RAM Error
2 x Orange
10
6300
EEPROM
3 x Orange
10
6800
Home Position
4 x Orange
10
5100
Temperature Sensor
5 x Orange
10
5400
Waste Full
6 x Orange
10
5B00
Needs Service
Cartridge OverHeat
7 x Orange
10
5200
Replace the BJ Cartridge(Printhead)
Cartridge OverHeat
8 x Orange
10
5200
Cartridge Displaced
9 x Orange
10
5200
Replace the BJ Cartridge(Printhead) or reinstall
Cartridge Displaced
10 x Orange
10
5200
Cartridge Displaced
11 x Orange
10
5200
Other Hardware error
12 x Orange
10
6500
None
None
5910
Needs Service
None
None
5C00
Needs Service
1.Open the printer access door. 2.Remove the black and color ink cartridges. 3.Reseat the printhead.
a. Lift the printhead release latch b. Reseat the printhead, pushing firmly on the white label on the printhead (if provided) or the center of the printhead, until it clicks into place.
NOTE: You may also visit www.kodak.com/go/printheadsupport for demonstration on reintalling the printhead
4. Close the access door. 5. wait for the printer to initialize.
If issue persists, the printer itself needs to be replaced. Call 1.800.421.6699.
Hi, its sad to say but the printer sounds that needed to be send to the nearest service center in your area. You already reseat & replace the ink cartridge and issue still present. Please call your printer manufacturer so that they can give you more options aside from sending it to service center. Thank you so much,
Well, here is the proper way of fixing or troubleshooting that paper jam error in your printer
Open the printer access door and remove both of the ink cartridge, then remove also the printhead, after that close the printer access door, without those parts. Then it will show a message in the printer screen, "Printhead is missing or has come loose" or "Printhead Not Detected" Install the printhead, just the printhead without the ink cartridges. After that close the printer access door. Then it will show you a message"Ink cartridges is not installed,install ink cartridges". then open again the printer access door, then install the black ink cartridge without the color ink cartridge. then close the printer access door, then message must be " Color ink cartridge is not installed, install color ink cartridge" then install the color ink cartridge." the message must be,"New printhead is detected calibration require, load paper and press start"
Thats the way of overiding the paper jam error message of your kodak all in one printer hope this will help you guys
by: E.brown
Happy Printing(", ) Kodak AIO tech support 1-800-421-6699
does the printhead run smoothly to the left side of the printer when it is powered on?
If the printhead cant run that freely, it will give you the paperjam message. You have to dismantle the printer again, connect the scanner and cables again when top cover is removed. Press the scanner open contact (opposite to the menu button) and watch the printhead run to the left side. It might be that either the printhead stucks somewhere on its way (press the cover of the printhead. It might be the reason) or the guide rail hinders the printhead to move.
