How to change door seal on a Hotpoint FEW12 washing machine
For most front-loaders:
Lubricate the slot which fits over the tub with washing-up fluid.
Starting at the top, press the seal so the flange of the tub enters the
slot on the seal. Work your way round the using thumbs to force the slot
on the tub flange. When slot is on the flange all way round, fit the
spring which holds it on. The spring goes into a slot on the outside of
the seal. This is quite difficult and you may need another pair of
hands. Fit the outside of the seal to the cabinet - this
is easy and fit the plastic clamping ring.
Test for leaks before
using. Use rinse to test as the water level is higher.
(There is no glue anywhere, only clamps,etc)
Pl rate me
nice for the free help!
