Some times my aspire 5100 doesnot boot. It says media test failure, check cable, exiting PXE Rom. It boots from CD and some times from hard disk also when i try again. I understand that it is a hard disk problem, but is there any solution short of changing the hard disk.Some times my aspire 5100 doesnot boot. It says media test failure, check cable, exiting PXE Rom. It boots from CD and some times from hard disk also when i try again. I understand that it is a hard disk problem, but is there any solution short of changing the hard disk.
You can't post conmments that contain an email address.
It is beacuse your Hard drive is not detected on the computer properly.
Try resetting BIOS.
If that doesnt work, Check whether your hard drive is good.
It is trying to bbot up using network boot because it cannot find OS on the hard drive, you can turn off the network in the BIOS setup page, but more likely you have problem with the hard drive or the OS is corrupted.
PXE error means that it is trying to boot from an ethernet / lan connection.
check your boot order options first and set it to boot
1. Hard drive
2. CD rom drive
3. Floppy (or usb if you know how to do this)
4. network(aka PXE)
If it still fails then yes there MAY be an issue with your hard drive.
Check all hard drive connections before running off for a new one.
This can be especially true with SATA type drives most of which dont have any sort of true locking device to hold the connections secure.
PXE errors are generated by the network boot ROM. In other words, the boot process is attempting a network boot (your BIOS' 4th boot option), which means that your system was unable to boot from a HDD, CD-ROM, or USB device (the first 3 boot options).
PXE-E61 Media Test Failure, System won't boot:
1.Go to Bios Settings 2.Remove LAN booting from booting options...For laptop ,type "X" on the LAN booting option. 3.Save The configuration
check connections of hard drive. 2nd check boot order in Bios, remove Lan or network boot from top order. 3rd choice if not solved reset bios by removing cmos battery and putting back in to clear it.
hi LWeller1l what you computer is trying to do is boot from a network and it's not picking one up so it gives you an error message, to check if it's just this....... go into your bios and check the boot order it should have ......cd/rom or dvd/rom drive as first boot option then the .........hd meaning harddisk then the pxe boot, if they in this in this order and the pxe option is not above the harddisk in the order you may have harddisk problem. when the computer boots it uses this order to start, so in this order it checks the cd/rom or dvd/rom for a bootable disk, if none is in there it then tries to boot off the harddisk, if this fails then look to the pxe boot option which is network boot option off a server,........another thing is you if you don't have server you can disable the pxe boot option completly in here........so if they are in this order in the bios then you may have to re-install the operating system or the disk may be corrupted or failed.
