HP Photosmart C6280 Printer Logo
Posted on Mar 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
"no scan options"
My hp printer photosmart C6280 won't scan pictures to my computer. it says "no scan options" instead of letting me choose a computer to scan the picture to.
Anonymous
Level 2:
New Friend:
  • Expert 55 Answers
  • Posted on Mar 27, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
55
Questions
0
Helped
22911
Points
173
" no scan options refer to device documentation for trouble shooting"
you need to open up either solution center or hp director, go to settings, scan settings, then scan to set up and look for the option front panel destination a window should open to reveal scan short cuts and one titled front panel list. you need to select the shortcuts click add and once satisfied click on "update device".
All in one printer c6280 hi, I want to scan a document to pdf file. I used to be able to choose this option on my c6280 scanner, but now i can;t. it tells me that i have to refer to device...
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=3194498
Above is the link to the manuals, software, and drivers for your printer.
uninstall the printer, reinstall it, and if the option to scan to pdf hasn't returned consult the manual.
1helpful
Scan to Computer is not one of the listed options. The only choices on the scan menu are Scan & Reprint or Scan to Memory Card. I need to scan and email documents but can't seem to get the ability to...
Did you install the HP software that came with the scanner? I believe it is called the "HP Solution Center". If so, you can open this program to scan. Once you scan the item, you will have the option of where to save the file.
How do I get my HP Photosmart C6280 to scan to my computer?
Open the printer manager and form the menu look for scan option.
How do I scan a doc from printer to computer
Make sure the HP Photosmart's driver is successfully installed to your computer. Then click the Start button, All programs, Accessories. There should be a Scanner and Camera option. Just click for that one and follow the wizard to scan your document and save it to your computer.
We have a HP Photosmart C6280 All in One Printer/Scanner/copier. We want to scan to computor.The menu only shows "scan to copy" and "scan to memory card" The manual that came with the...
If possible, find the software disk that came with the printer, and reinstall. One of the options should be to scan from the scanner to the computer. Just make sure that option is selected on re-install, and that the necessary communication cables for that option are installed.
7helpful
HP Photosmart C6280 Scanner
Hi - You can download the manual by clicking the link underlined in blue below:
Photosmart C6280
See page 80:
You will need the "All in One" software for your computer:
Software
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Problem scanning pictures
Check your documents folder under My Scans. I found that my scans were going in there. I had to open them to put them where I wanted them.
I also have the problem of the missing line up upload to my computer. If I restart the computer with the 6280 on the line reappears and I can scan what I want. I have asked HP what the problem is with no real solution. They seemed to think that since it works after restarting the computer that the problem was solved. The option shouldn't disappear from the screen at any time, but I guess I'm stuck with restarting the computer every time the problem comes up. Hope this helps.
2helpful
4answers
Users manual for hp photosmart C6280
The user manual (and other guides) for the HP Photosmart C6280 are available from HP at: http://h10032.www1.hp.com/ctg/Manual/c01150745.pdf
The tray selection is not listed well in the index, but the informaton you are looking for is probably found in pages 38-40 which deal with using the photo tray.
Regards,
Bob Headrick, MS MVP Printing/Imaging
k24674
Grand Canyon Tech
Grand Canyon Tech
