Question about GE Freezer  14.8 Cu. Ft. Manual Defrost Chest Freezer
Light not working in GE chest frezer it is larger than the model below, 22 cf, it is 25 years old.
  • 316 Answers
Check the bulb, check the tabs within the socket, check the door light switch.
Please, unplug fridge when testing these. We'd like to hear from you again.
Posted on Mar 31, 2010
SOURCE:
I have a Skandiluxe CF 136 chest freezer & the orange (fast freeze) light is on all the time.
The compressor won't burn out just because it's running all the time. The plastic fascia pops out easily from behind(take the little panel off on the side) Set the thermostat to the middle of its range and switch the fast freeze off.
Oct 08, 2015 | Freezers
Lid on chest freezer will not securely close Model #FCM 7DAA WH Serial #RTI63278 Mfg 81998
Remove lid, squeeze hinge back into shape and refit, adjusting screws in rear of hinge bracket as you do.
May 19, 2012 | GE Freezers
We've got a GE American Fridge Freezer. 12 years
time to get a new freezer. check the floor under the freezer for coolant leakage, if none the compressor is ready to deep 6...
Nov 07, 2009 | General Electric Chest Freezer FCM5SU
After clean, the magic chef chest frezer no linger frezen.
I think in the defrosting process, the evaporator was damaged causing refrigerant leakage. sorry... dont try to repair.. it sucks in moisture
Aug 26, 2009 | Freezers
I have a GE chest freezer and the exterior green light has started flashing. The freezer is less than a year old.
Is this just a "Power-on" light to let you know it's plugged in and has power? This is probably just a "neon" (although the actual gas inside is hydrogen for the green color) bulb and sometimes they will do the flickering thing literally forever. In a way it's a good thing as it makes you look at it. If it really concerns you, or if it is actually a warning that something is going wrong (it should say in the manual, you DO have the manual don't you?) have it fixed under the warranty.
Jul 07, 2009 | Haier 5 cu. ft. / 142 liter Chest Freezer...
General electric 5.0 chest freezer has water coming all over the floor.
The reason this happens is because the defrost timer is not turning back on when it needs to, causing the freezer to thou out and overfill the drip tray sitting on top of the compressor. A new defrost timer should be available from the local refrigeration wholesalers in your area.
May 11, 2009 | General Electric Chest Freezer FCM5SU
Chest Freezer not cooling
Please don't rate this solution, as anything but FixYa brings my rating down, but here's what you've got:
You have a refrigerant leak (commonly referred to a Freon, but these days usually R134A refrigerant). Some refrigerant has leaked, so you are still getting some cooling, but there is not enough refrigerant left to cool throughout the entire evaporator coils. This is NOT a repairable condition, as the coils are foamed in place and not accessable for leak repair. If this unit is under 5 years old (typical sealed system warranty) the manufacturer will most likely replace your freezer with a new one. If over 5 years, you are out of luck. Buy a replacement freezer.
Oct 12, 2008 | Whirlpool 10 cu. ft. / 283 liter Chest...
Kenmore 23.1 cf Chest Freezer not cooling below 14F
Make sure everything is working, I.E. compressor, fans. Now I need to know if the freezer shuts off at 14 degrees, or does it continue to run without making temp. If it shuts off, then the first place to look is the thermostat. It may be out of calibration. If it continues to run, then the solution may be as simple as cleaning the condenser coil. or the defrost has malfunctioned somehow. Defrost probleams will cause excess ice on the inside coil. You may need to remove the panels to see how much ice is on it. It sounds like the compressor is good, as it is pretty cold. Just not cold enough. A deep freeze should be at least 0.
Feb 19, 2008 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Turn the unit on
Tried holding button for more then 4 secs? What model/make is it?
Jul 29, 2007 | Kenmore 14.8 cu. ft. / 419 liter Chest...
GE Freezer  14.8 Cu. Ft. Manual Defrost Chest Freezer Logo
224 people viewed this question
Top GE Freezers Experts
craig nesmith
Level 1 Expert
Gil Shultz
Jay Finke
Jay Finke
Are you a GE Freezer Expert? Answer questions, earn points and help others
