You could try resetting the computer. The car maybe in lockout mode. Try turning your car over….leave the ignition on. Wait exactly 10 min. Then try turning over again….again leave the key on. Wait exactly 10 min and do it a third time….this time the car should start…maybe run a lil rough while it relearns the processes of your vehicle again. It is important to wait the exact 10 min each time. You will probably need a battery charger or a set of jumper cables because if your car goes low during this process it will not work. Good luck and I hope this works.
CAR NO START PROBLEMS:-----
It
can be the issue with weak battery or faulty battery or if battery is ok,then
its faulty starter causing the issue.
From
start to end troubleshooting these problem i suggest you to click the link
below and follow its procedure:-----
What to Do When Car Turns Over But
Won't Start?
http://technoanswers.blogspot.com/2012/11/what-to-do-when-car-turns-over-but-wont.html
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
http://whoisbyme.blogspot.in/2012/06/car-starting-problems.html
http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html
http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html
http://whatisbyme.blogspot.in/2012/06/1999-chrysler-cirrus-8-ign-fuel-starter.html
http://whatisbyme.blogspot.in/2012/05/2001-toyota-camry-no-start-after.html
http://whatisbyme.blogspot.in/2012/05/1995-lexus-ls400-running-hot.html
http://www.howtorepairguide.com
These will help.
Thanks.
It
From
Won't Start?
These will help.
Thanks.
