SOURCE: Craftsman Chipper-Shredder Model No. 247.775870
If a small engine wont start its usually one of two problems, its not getting gas, or its not getting spark. easy way to find out if its getting a spark is to remove the plug, put it back back in the connector and just let it hang down while you try to start it. you should see a bright blue spark, if you dont try changing the spark plug. if its getting a spark come back on this site and i'll help you trouble shoot it.
SOURCE: 9hhp craftsman chipper shredder won't start
Squirt a couple of spoonfuls of oil into the spark plug hole to increase the compression as it has been sitting so long. Also squirt a little starting fluid into the carb. and give it a shot I think it will start. Hope this will. donnyb60
SOURCE: How to sharpen blades on a Yard Machine 6.5 chipper
http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=10151
above link will provide a pdf of manual
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
SOURCE: replace flails on 5.5 Yard Machine
Go to www.ordertree.com. The flailblade is p/n 719-0329, The shredder blade is p/n 942-0571, The chipper blade is p/n 981-0490.
Replace them you have to take casing off the unit to get to them.
Testimonial: "I have the casing off,and have penitrating oil on the pins and screws ----- tomorrow is an other day!"
SOURCE: craftsman 8.5hp chipper/shredder model 247.775880
Here is your link to your machine at Sears parts. There is a tab for downloading the manual on the right. The manual most likely will have oil drain and oil fill locations mentioned under maintenance.
http://tinyurl.com/4numvf3
