H20 Error showing on WF640 1400 Spin washing Machine
The error indicates a problem with the incoming water supply.
Check for restricted or kinked inlet hose/s, check that tap/s are fully turned on and that you have adequate water pressure.
I was getting h20 fault code not because not enough water getting in because over filling start machine and it would just fill up with water then h20 would come on nothink else. I put the machine on spin to empty water out and removed the plug then removed the two screws that hold the top cover on then remove the plinth cover at the bottom at the front of the machine tilt the washing machine back so you can get under the machine put some towels down and remove the black rubber hose that connects from the drum to the pump clean it out wash the white ball inside and replace then take the filter out of the pump just to make sure it's clean whilst it's there then put the machine back on the floor flat remove the vac pipe from the pressure switch and blow it should be clear if not remove and clean machine should now be ok if not pressure switch is falulty..hope this helps !!!
I have a h20 low wash system it won't spin to drain
