When we turn the TV on, at evened interval of 2-3 minutes the screen and sound momentarily goes off, and comes back on after 1 minute. The whole time the TV's power is on (there is a green light).
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Ur tv LCD inverter board it dead.Replaced this LCD inverter board ur tv picture will return.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
Hopefully you still have under warrantee. If not, sorry. This line if memory serves me right is because the tv has 2 picture panels on each side of the TV (they join up together to make one picture). Toshiba did not realize that the panels will start slipping thus creating this fine line from the top of the screen to the bottom. They have revamped the newer models and placed glass to adhere the panels together. Even though my TV was under warrantee I got a new one and have had this one for 1/2 year and now the picture just blew (there is sound but no picture.) Take your TV back if it is under warrantee.
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
> IF IT WASNT DIGITAL HD I WOULD HAVE SUSPECTED HIGH VOLTAGE POWER SUPPLY BUT THAT DOES NOT EXIST HERE. Well, not completely true; the fluorescent backlight is still a high voltage device, even if only hundreds of volts instead of kilovolts, and either the lamp(s) or the power supply for it (them) is causing the dropout of your picture.When it does it next time, look at the screen from various angles, I think you will see that video content is still there.
