First, if there is still water in the drum lower the outlet hose into a bowl and if no water comes out then you have a blockage but if water flows out then the pump is at fault. To clear a blocked filter on a WMA machine which still has water in it, first tilt the machine backwards and open the door, bail out the contents of the drum with a mug or sponge untill it is as empty as you can get it. Now lower the machine back down again and remove the lower inspection panel at the back of the cabinet now tilt the machine forward.....place a tin of soup or something under it to hold it in a tilted possition, then put a bowl or deep oven dish under the sump to catch any remaining water when it is removed. Undo the retaining clip around the sump hose and disengage it from the container, the filter is inside the hose and can be taken out to be cleaned.Click the links for Workshop manuals on Hotpoint WMA and WM machines
