I assume you mean how do you turn on the griddle? Try the symbols, and if that is not the solution, turn each on individualy until the one that heats is the one you want.
Yes, Lodge made a nice 20 inch cast iron griddle has bigger surface to cook more food with two side handles to make it easy to move. You have some other options like Presto 22 inch griddle, check out this link for different size griddles and pans with detailed information. GroomNStyle Top 5 Best Saucepan and Pot reviews 2015
I have the same thing happening with my Viking griddle. I have nearly the whole top seasoned to a jet-black state - and it is stick free!! Now up near the front edge the coating/seasoning is chipping off. I've just been taking the loose chips off and not worrying about it too much, it maybe the size of a half dollar at this point. The front edge of the griddle is the hot spot on mine; and I've learned to adapt my cooking techniques. My guess is the hot spot on my griddle is responsible for the flaking...
This is taken verbatim from page 11 of my Frigidaire Gallery range:
"Seasoning, using and caring for the griddle Before first use:
-Wash griddle in hot soapy water. Rinse and dry completely.
-Apply a thin coat of vegetable oil to the entire surface (front and back of griddle).
-Preheat your oven to 350*F. Place the griddle on the upper rack in your oven.
-Bake griddle for 1 hour at 350*F, then turn oven OFF and let cool before removing.
-The surface may have a tacky feel to it from the seasoning process. If desired, wash the griddle in hot soapy water, rinse well, and dry completely.
Using the griddle:
Remove the center burner grate and carefully replace with the griddle (some models). Preheat the griddle for 5 minutes on medium to medium low setting. Slow preheat ensures even heat distribution during the cooking process.
DO NOT preheat the griddle on HI setting. Preheating on HI may warp the griddle and prevent even heat distribution.
After each use:
-To prevent rusting, store in a dry place and keep uncovered.
-After each use, clean with a stiff brush and hot water only.
-Do not clean griddle in the dishwasher.
-Dry immediately and apply a light coating of vegetable oil to griddle before storing.
My husband and I just had to check out our griddle on our 48 inch Viking rangetop. You remove the grates and the grate holders on either side of the griddle..it just pops out. Then you raise your griddle up about 4" to remove your thermastats., noting the position they are in so when you replace you can put back correctly. After pulling the thermastats out, then you lift the griddle out. Griddle is extremely heavy so be prepared to have close surface to lay it. Hope this helps.
Carole
If it doesnt fit your specs. then i would suggest u find a thermador parts place and begin to buy the parts for the griddle as replacement parts. find a model of the stove set up that you want and make a list of all the parts that go to the griddle attachment.
My guess is that the reason for the flat "No" on the retrofit was that griddles require a thermostat similar to the one on the oven and broilers do not. So if their is no room behind the face plate where the knob would go then you can't put in a griddle. The other issue might be that the burners for the griddle wont line up with the brackets that are holding up all the broiler burners now. The griddle burner looks exactly like the one from the over only smaller so it has to line up strait where a regular front and back burner have to line up offset. maybe since you have the broiler already that should not be an issue? Then the problem is finding the griddle top it self that is going to be spendy. I think the link i gave at the top is your best bet. good luck.
Leslie
