SOURCE: setting the alarm on my clock radio
use the selector switch on the top, switch it to wake 1 or wake 2. set the time that you want that alarm to go off. then push the switch all the way back to the left to deactivate it. then to activate the alarm, use the buttons on top labeled wake 1 or wake 2 to turn the desired alarm on. pushing that button repeatedly will cycle the alarm to either beep, radio, or it will turn that alarm off.
SOURCE: how do i change from military time
This may or may not work. The 40009 and 40010 are almost identical. The 40009 doesn't mention military time and the 40010 does, so you might want to what the manual says. 40010 manual and 40009 manual. According the 40010 manual, is says:
Displaying the12/24 hour, Date, Month and Year:
Display the 12/24 hour by hold the "+" button for 2 seconds. To display the date, month and year by press the "-" button, the year appears and then if pressed again, the month and date (eg. “12 31” means Dec 31) appears.
So maybe that will do. I have a 40010, but my manual is different from the one on the website. Its DST button and not Alarm Set button to change the time. So maybe try holding down different buttons for a couple of second see if one lets you change it between 12 and 24 hour. Good luck, hope this helps.
SOURCE: I have a CKS3030 Smart Set alarm clock and I
This is a problem in the led display driver circuits.The circuit may have developed some problem with cold solder joints due to heat and vibration problem. The problem could also be in the led's driver circuits that supply power to the leds display for operation. This type of problem should be handled by a qualified service technician. You can call Emerson customer support at this telephone number. 1-800-909-1240. Between the hours of 8am-4:30pm CT. Give them the make and model number of your Clock/Radio and ask them for assistance. I hope this information helps you understand your problem. Thank you for using FixYa and have a nice day.
SOURCE: Need instruction for setting clock model # 38229-1
Setting timezone: Enter alarm time preview, by pressing "Mode". Press "Adjust" to change time zone.
Setting time: When previewing time, press and hold "Alarm on/off" Until time blinks. Press "Adjust" to change time; Press "Alarm on/off" to change to minutes, ect. Press "Mode" when done.
Press and hold the "Alarm
Set" button for five to seven seconds and the year will begin to blink when the clock is ready for
adjustment. .
Set the year by pressing the
right-arrow, "Up" or "+" button, depending on your model of
clock.
Set the month, day, hour and minute.
Press the "Alarm Set" or "DST" button to cycle through each
field, and use the "Up," "+" or right-arrow button to
adjust the values within each field.
Press the "Alarm
Set" or "DST" button after setting the date and time to store
the information into your clock's memory.
Press alarm 2 to change from Celsius to Fahrenheit.
Press alarm 1 to change from 24 hr time to 12 hr time.
