Sony Walkman NWZ-B105F MP3 Player Logo
Posted on Mar 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MTP drivers for sony walkman for winxp
My win xp do not install mtp device drivers for my sony walkman..
Muntejaya Ginting
Level 3:
  • Master 10,422 Answers
  • Posted on Feb 20, 2011
Muntejaya Ginting
Master
Level 3:
Answers
10422
Questions
Helped
2468534
Points
19564
26helpful
3answers
Sony 16g Walkman NWZ-S545,but system will not recongize it !
If you have XP SP3 installed , you might face this problem.
Go to the Device manage. Click on the update driver of the sony walkman device driver. When the dialog box appears select, choose install from a specific location, then click next.Then in the next part of the wizard, select don't search, i will choose the driver to install and click next. then choose from the portable driver, select USB root hub. Click next and finish. You are done and enjoy the data transfer and music.
3helpful
Can't get the right usb connection on my mp3 to download music.
Win Xp -> Go to Start-Control Panel - System - Device Manager - Last on the list is MTP player, click on it and select upgrade driver - i will choose myself - i there will be two options ( MTP player and USB mass storage device ) Pick Usb mass storage and then OK. Then your MP3 player is visible in My Computer
24helpful
2answers
I installed my sony NWZ as MTP device, but now i want to go back to simpler UMS (standard usb connection) ive tried removing the mtp drivers from device manager, but it always just auto installs... Can...
Since there's no easy option in the Walkman's settings to switch back and forth between MTP and UMS, there's a little trick to un-do the MTP drivers so that the unit becomes a straight USB Mass Storage drag/drop unit. You have to go into Device Manager (Windows XP), find the Walkman in the Portable Devices group, right click, then select Update Driver. Then select "No, not this time", then Next. Select "Install from a list or specific location (Advanced) then Next. Select "Don't Search, I will choose the driver to install", then Next. (Be sure to check the box beside Show Compatible Hardware) Highlight USB Mass Storage Device, then Next. (To revert back to MTP, just do the same thing but choose MTP instead of USB Mass Storage Device.) Personally, I'd never go back to the MTP mode. Having the Walkman seen by the computer as just another USB mass storage device allows the drag/drop transfers to go much faster
28helpful
6answers
Sony nwz-b135f problem
MTP problem SOLVED!!!!! Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} I have a Sony MP3 Player(NWZ-B135F). when i inserted it to my pc's USB port(which is working fine), win XP (SP 3) prompted "Found New hardware" wizard. I followed the steps and finally I reached to a step where it shows “MTP device Problem......” I tried many times with different USB ports, but the same problem happened.
Fully frustrated, I finally did what the whole world does, GOOGLE my problem. Google showed me a lot of posts but nothing could solve my problem. Microsoft was providing the MTP driver, but only after a lot of authentication and procedure, which I was not going to follow….
After repeatedly experimenting by inserting my MP3 player, I got the solution!! It is as follows:
1) Insert your music player in the USB port. You will get a Hardware Installation wizard by XP.
2) Select, “No, Not this time” and click next.
3) Select “Install from a list or specific location (Advanced)”.
4) Select “Don’t search. I will search the driver to install”.
5) Select “USB Mass Storage Device” and then click "Next"
7) Wow!! Now you are done!!!
Enjoy and listen to your favorite music!!
SONY NWZ-B105F device driver/mtp device driver
when it says cannot find driver you go to file then refresh plug-ins and that should bring up the driver
5helpful
My mp4 player wont connect keeps coming up connecting usb mtp
Great Solution by  DCDW
Rank: Apprentice
Rating: 95%, 43 votes
I first found that when I plugged my player into my computer it registered it as a MTP (Media Transfer Protocol) device and in turn never showed up as a storage device on my computer. I fixed this by going into my Control Panel -> System Icon -> Hardware Tab -> Device Manager button.
Clicking on the "System Devices" tab should have "Walkman" or MTP device. Right click on it and go to properties, now before doing anything it should say "Location -- ------ Location 0 (Walkman)" if not try unplugging the walkman and see if the MTP device you're looking at is removed from the list, just to make sure it's the right device we're looking for.
If you've confirmed it's the Walkman, click on the "Driver tab" and click on "Update Driver...". Then click on the "Install from a list or a specific location (Advanced)" option and click "Next". Now select the "Don't search. I will choose the driver to install." and click next. It should now bring up 2 driver choices, one being "MTP Device" and the other "USB Mass Storage Device". Select the USB option and select next, it will then install your walkman as a USB storage device and after that's done. It should be a matter of unplugging and plugging the Walkman back in and it should show up on your storage options in "My Computer"
3helpful
2answers
NWZ-B103F MP3: connected to USB port on pc( vista) and tried on laptop( xp)
52helpful
2answers
My sony nwz-S616F doesnt transfer songs from pc
Sony NWZ-S616F
Dear holders, I have it and solved all problems which are in discussion. Just read all INFERNAL help, it works! By XP, go to Start-Control Panels-Administrative tools-Computer Management-Device manager (small icon of computer on your left hand side) tab should have “Walkman” or MTP device. Right click on it and go to properties, now before doing anything it should say “Location — —— Location 0 (Walkman)” if not try unplugging the walkman and see if the MTP device you’re looking at is removed from the list, just to make sure it’s the right device we’re looking for.If you’ve confirmed it’s the Walkman, click on the “Driver tab” and click on “Update Driver…”. Then click on the “Install from a list or a specific location (Advanced)” option and click “Next”. Now select the “Don’t search. I will choose the driver to install.” and click next. It should now bring up 2 driver choices, one being “MTP Device” and the other “USB Mass Storage Device”. Select the USB option and select next, it will then install your walkman as a USB storage device and after that’s done. It should be a matter of unplugging and plugging the Walkman back in and it should show up on your storage options in “My Computer””. Holla for original uploader Inferno!!!
42helpful
9answers
MTP DEVICE Sony 4gb walkman NWZ-S616 not installing
if you have a problem about MTP Device and wont be able to show in your "My Computer", here are tips that may help you fixed your problem:
*First- Uninstall the MTP Device Driver in your system.(Right click My Computer then manage, then click Device manager at the left part, then after that, find MTP Device in your right part, then click and Right click the name of your MTP Device then uninstall.)
*Second- Reconnect the device and then after a pop-up show which says, New hardware found,
click install the driver in a specific location, then choose the bottom option and then choose
Storage Device.
*Lastly- Turn On your Device and search it in My Computer.
that's all, and i hope i do a little help to you!
Mark Anthony Quintana
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
