I recently changed from Windows XP to Windows Vista OS. I need the driver for my Mustek 600 CU Flatbed Scanner which had been working on the Win XP. Thanks. Tony. ([email protected])
i have a mustek 600 cu which i have not used for a while... i now have vista and have lost my software installing cd and wondered how i can get this to work....grateful for ny help thanksi have a mustek 600 cu which i have not used for a while... i now have vista and have lost my software installing cd and wondered how i can get this to work....grateful for ny help thanks
You can't post conmments that contain an email address.
You don't get a Driver for Vista for your scanner but you can use the windows XP one. It will work as well. You can download them at the site below.
http://www.mustek.com/mustek/supportdrivers.php
Hope it helps
Regards,
Hi, Mustek doesn't appear to have released a Vista driver for this scanner. If you go to Mustek's A3 EP support page, there is only a Windows 2000 driver, which seems to be the same one for Windows XP. Have you tried using this driver in Vista, to see if it works?
From reading around, there isnt one....But i found this post
I've just installed a Mustek 1200 CU scanner on Vista.
I used the XP driver from the Mustek website.
You have to temporarily edit the registry to make the installer think you have XP
In regedit, go to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsNT\Cu rrent Version Find the "product name" key. Carefully record what it says before you start. (eg paste it into a document somewhere).
Then change it to make it read: Microsoft Windows XP
Then run the Mustek XP installer, and change the registry key back to saying Vista.
The scanner works fine in Photoshop, for example, but the Vista scanning wizard doesn't detect the scanner. Don't think it uses TWAIN?
Run a Google search for your scanner and see if an XP driver is available. Since the original driver was for Win98, I doubt the scanner will work with XP. Just too old.
there is not drivers or software made for Windows XP.
however, you can use the win98 or WinME software. as long as the Windows Xp is running at 32 bits. I have done that with HP flat bed scaner.
don't worry about the non-certified software with MS.
go to mustek usa/canada website and download the drivers for the mustek bearpaw 1200CU Plus scanner for Windows xp. its about 18Mb in 3 large files, run a web search for the mustek scanner, and windows xp and you should get a hit.
Artus
I have recently changed from windowsme to windows vista. I have the disk for the scanner but I need the drive. Can you help
I need a Vista driver for Plug-N-Scan 600 CU Scanner please. No problem working on XP until migration to Vista.
