Question about Chaika Appointment (amazon-stone)' Ladies bracelet filigree wrist watch Siberian Gems (gold+cobalt p...
I need to find someone who can make a crystal
I have a chaika watch that needs a crystal, and I trthink it needs to be hand made.
  • 2,338 Answers
If your watch crystal is round, there is no need to hand made it. Visit your nearest watch repair shop and ask to order one. Rate me , plz.
Posted on Mar 26, 2010
Testimonial: " Thank you for getting back to me. My crystalis not round it is somewhat shaped like a shield "
SOURCE:
How do I remove the crystal of this watch?
Hi Niko, the face of the watch is usually accessed from the back by removing the back cover, mechanism and the winders. I would recommend taking it to a watchsmith who will hopefully replace your second hand at a reasonable price.
If you want to try it yourself, there is a risk you may be un-"watchable" ;) How to reset watch hands
Oct 09, 2018 | Diesel Watches
Battery on m Invict Pro Diver watch replaced , now the second hand stays swinging back and forth in the same place
Do the minute and hour hands keep proper time? I've seen your problem before when the hand has come loose from the center post that turns it. You probably need someone who knows what they are doing to pull the crystal and reseat the second hand. Do this when the watch is off!
Sep 08, 2014 | Invicta Pro Diver 9309 Watch for Men
How can I changw the glass for this watch?
In order to replace the crystal on your watch you are going to have to remove the entire movement and use a watch press to remove the crystal.
this is not an easy job and should be done by a professional
First you will need to get a watch back opener to unscrew the back of your Tag. The three slots should fit into the back of the watch. tighten the opener until it is firmly on. then turn counter close wise until back of case comes off.
Next you will need to remove the watch hand and crown. Becareful doing this for pressing to hard will break your set leveler. You will need a thin pin pusher and look on the back of the movement for an arrow pointing toward a hole in the movement. Push down and at the same time pull the stem and crown out of movement. turn the watch right side up and the watch movement should fall out. Place movement on a very safe spot so not to damage movement or dial
now you will you be ready to remove crystal Since it is a friction crystal you will need to do use a watch case press . find two die that fit exactly the watch and crystal use a scooped side and place it on the bottom side of the watch press. Next use a flat die to place on top of the case press. place the watch face down. you will be pushing the watch crystal out from the top. Press down on the level and check to see if the crystal came loose, keep doing so till the crystal comes out.
finally you will need to measure the thickness and diameter of the crystal and find the exact size. I believe this watch has a sapphire crystal so you will need a sapphire crystal too.
Once you buy the proper crystal it is time to put the it in the watch. Place the watch face up in your watch press. and slip the crystal in through the top making sure its perfectly even all around. Slowly push down on the leveler until proper pressure is applied and the crystal snaps in.
Now you have new crystal . Clean crystal thoroughly and the inside of the case. Place watch upside down carefully place movement back in. slide spacer in . Now slide watch stem and crown back in push down again on the set leveler with pin pusher.
Place case cover on back and tighten properly to prevent water or moisture from entering and you are done.
This repair should be done by a professional especially on such a nice watch. Any watchmaker can do this job and will have the tools to do it properly
Jan 27, 2012 | Tag Heuer Carrera GMT WV2113.FC6169 Wrist...
The crystal face of the watch is cracked. We need to have the crystal replaced. Where do we send it in? Our watch repair doesn't handle things like that! It is an Akribos watch.
there are many different options, you can "google" watch repair, and choose someone to send it to. any local jewelry store should be able to give it to their watchmaker for a replacement crystal.
Jul 17, 2011 | Watches
I need change the glass.where?
It is possible for jewelers to order exact fit replacement crystals for many watches. However, generic replacements are not made for all watches. If your jeweler cannot perform this service (which may cost as little as $10 for common crystals), ask if the jeweler knows of a jeweler's specialty business that can custom-fit crystals. These small shops custom-grind crystals from blank stock and hand-fit them to your watch. Such companies used to be relatively common; today, most conduct operations via mail-order or exist in large cities like New York where there is enough local wholesale and walk-in business.
Department stores and chain jewelry stores rarely have the on-sight resources to service a broad selection of watch crystals. Seek out an independent jeweler or one that has a "we repair watches" sign displayed.
May 06, 2011 | Cerruti Genova Swiss #CT69051X403021 Watch...
If one of the hands have fallen off the face of the watch. can it be repaired by taken the back off or the crystal face? If the crystal face can be removed what is the proper way to remove the crystal
Thank you for contacting FixYa.
Hands are fixed through the back of a watch but due to the delicate nature and complication of this type of repair, it needs to go to a watch repair service tech.
Best regards. Jewel
Sep 18, 2010 | Watches
Chaika watch
You probably visited jewellers, not the proper watch repair shop. Even if the crystal is curved, there are suppliers. If the crystal is not round, then this should be hand made.
Mar 27, 2010 | Chaika Appointment (amazon-stone)' Ladies...
I need a crystal for a chaika watch
you cannot do this yourself ..try the manufacture or a competent repairer some crystals have to be made by hand if theres not one available through the trade repairers..
Mar 26, 2010 | Watches
The analog portion of my Casio watch has a problem. The hour hand is lagging. Ex at exactly 3:00 the hour hand will not be on 3 it will be at about the 14 minute mark. Can you help? I recall my Citizen...
You will need to remove the crystal, but without proper watchmaking tools and skills you will not be able to do the job. If you do not want to damage your watch, you have to find your nearest watch repair shop and ask to fix it.
Aug 10, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Hi, One of the hands has fallen off my Skagen watch; the crystal will have to be removed to re-attach it. Who can do it, and for how much?
Just about any qualified jewler that sells watches will either be able to do the work or refer you to someone that can. The crystal shouldnt have to be removed. The case back comes off and then a retainer ring of plastic or metal comes off. The crown is removed and the movement should come out. I wouldnt suggest you try it yourself as jewlers use special tools and jigs to attach hands. Cost shouldnt be too bad depending on the jewler.
Jul 22, 2009 | Watches
Chaika Appointment (amazon-stone)' Ladies bracelet filigree wrist watch Siberian Gems (gold+cobalt p... Logo
85 people viewed this question
Top Chaika Watches Experts
Arturs Kalnins
Arturs Kalnins
Marvin
Marvin
Are you a Chaika Watch Expert? Answer questions, earn points and help others
