Fossil Kaleido Green Kaleido BG2146 Watch for Men Logo
Posted on Mar 26, 2010
I replaced both batteries. the background will flash it has a college emblem in background, but the hands wont move. second hand wont move.
  • Anonymous Mar 31, 2014
    second hand not moving
Anonymous
Level 1:
New Friend:
  • Contributor 51 Answers
  • Posted on Mar 26, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
51
Questions
0
Helped
16806
Points
79
Check batterys are not faulty, but i think you need to AC the movement,ok. refit both batterys then onthe movement itself there should be two letters AC or AR or sometimes AS and close to these letters a small area no bigger than 3mm in diameter you need to place one prong of a pair of tweezers on this area and the other prong on the movement itself make sure its the metal part of the movement do this at the same time like tapping two fingers together on a desk but remember you may need to do this a couple of times
How do I restart the second hand on my seiko coutura kinetic perpetual 7d48 after changing the battery?
I found a way to get my second hand ‘unstuck’. It would only wiggle when I pressed the button to show the charge. After replacing the capacitor and reassembling very carefully, I pulled out the crown halfway and turned it to advance the date by several days at once. The second hand started moving again right away. It was advancing a second at a time not two, so it had charge. When I checked the amount it showed almost full (new capacitor was already charged).
I just bought an Emporio Armani AR2020 wrist watch and when I received it, the hands on the watch wouldn't move. Do I need a battery for the watch? Is it broken?
That specific watch has a quartz movement, and it does not have a sweeping hand that moves to count the seconds. If the hour and minute hands are not moving there is a possibiliy that the battery has died. If after the battery is replaced and the hands still do not move then it's an issue with the quartz movement.
Dec 25, 2012 • Watches
Swatch diaphane second hand stuck
Hello, a week ago the small second hand (not long chrono second hand) got stucked and my irony swatch just stop moving. Although the chronometer could be running if started... The small hand just didn't move.
I tried different tricks, like removing battery, pull out main wheel and use chrono buttons to reset arms. Etc.
Today I noticed that when turning the wheel backwards a couple of times (one or two hours back) the little hand moved one second back... Pushing wheel back to On possition made the small hand move forward one second and get stucked again.
Then I did this procedure a couple of times, at some point I turned the wheel back for a while (may be 5 full turns) and noticed the small hand moved more than one second (5, 10, 15 seconds backward)... when I noticed it was moving freely I pushed wheel to on position and noticed the small second hand was running normal.. I hope it works for some of you. Greettings from Canada
4helpful
2answers
I have a big tic fossil watch. The flashing second is working properly, but the hand doesnt. It looks like slowing down. How can I fix this problem. Thank you
your watch has two batteries inside, the small battery is the one that had to be replaced. it is under the big battery, the small battery makes the minute and hour hand move while the big battery makes the seconds flashing. i hope that i had been helped you.
1helpful
2answers
Brand new technomarine watch chronograph csx wont work? do i need to dosomethin to start it??
Change battery. Watch can be brand new, but battery is fitted when watch left production line.
65helpful
2answers
Second hand doesn't move for each second
Your TAG is fitted with EOL (end of life) feature. This is the cause of that 4 seconds interval movement of seconds hand and thus indicating the time for battery replacement. The timekeeping is not affected by this- it is just warning to replace battery a.s.a.p.
Find your nearest watchmaker and ask for battery replacement.
Do not forget to rate, please.
27helpful
Second hand movement
9helpful
2answers
The second hand of my Tissot watch T870/970 starts and stops.
Hello!
Absolutely astonished by this "solution" from escapement.
This watch is working perfectly - it is simply giving its "end of battery life warning".
Dec 20, 2008 • Watches
1helpful
Second Hand
it is the battery life indicater get the battery replaced it will fix the problem
Top Fossil Watches Experts
john h
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Fossil Watch Expert? Answer questions, earn points and help others
