Hi
Please tell me how to format my Nokia 6300,
or please tell me how to unlock/break password of my memory card so that same can be used in another mobile phone.
I have nokia 6300 set, i have much messages in inbox as well as in sent items, due to which my cell stuck and automatically turn off and then get ON, now I want to format my cell completely, when i want to open inbox, outbox, sent items or drafts then it says "Message storage memory is not ready. plz help me in this regard.......
i am facing the same problem bro...
I have a same problem so can u please send me the solution in my mail id
[email protected]..
The default security code for Nokia is 12345.
You can recover the password. The best way is to download a file manager to your phone. I use Best Fileman for my N70, from http://www.smartphoneware.com/ It’s for series 60and 40. The trial version should be enough, it’s only £5.60 anyway.
In the file manager (when installed on your phone) you’ll find under- C:\System\mmcstore -the file you’re looking for, you have to rename the file- mmcstore.txt -then send it to another mobile (best way) or your PC via luetooth or USB, open it on the other phone and your password will be revealed.
Rename that file- mmcstore.txt -to just- mmcstore -there might be another file named- mmcstore.txt -to view your password rename one or the other- mmcstore1.txt -one is for your phone PIN number the other your MMC card.
Clear enough?
If you reset (format) your phone you will lose all the data stored on it. Resetting sometimes gives negative results. You can reset it through your menu, if you can switch the phone on of course.
Using the reset code is not recommended.
Try this:
Take your SIM card out.
Make sure your phone battery is fully charged.
Press * 3 send at the same time and turn the phone on. Keep them pressed until the reset screen appears.
Give it time to reset.
Yes! I know. You need someone to press the ON button.
where is nokia 6300 cant find it plzz help
hey nothing happens when i press the *3send.i thing it just only works on S60 phones right?? pls tell me how to format my nokia 6300 i cant add any config. settings it only says memory full even i dont have any settings yet.
Hey sir, i'm Raymond, pls i wil be grateful if u give me a hand/solution 2 my problem. De phone has a been a problem 2 me eva since. Sir pls how can i delete copyright file lik ringtone,themes etc 4rm de phone. I need ur help seriously
How is code to format nokia 6300
Please help me i cant reformat my nokia 6300...this is my IMEI 354864026989336
Hi my micro sd card is locked after I updated my phone ( Nokia 6300) ......Now my phone works , but my memory card is locked.....need password. p.s. I did NOT put any pwd....neeed help
I have Nokia 6300 cell phone. Now it having hanging problem.Actually it happenned after one message. Screen always show SPEAK NOW . I dont understand what is this. Alwas show volume increasing or decreasing. Reply me
Memory card removed? Nokia 6300Where's the format button? :O
Fomat
I have 6300 nokia phone.i hv problum to open memmory card. its error show memory card not formated,format memory card? but i dont wana to format memry card.what i do for open it?
Find your solution from the list,
Nokia 6300
Codes:
Software & Hardware Problems
Find Your Solutions for Nokia Phones:
Nokia N95
Nokia N73
Nokia N70
Nokia 6600
All the other Nokia Phones.
Hi all!!!
My nokia 6300 cannot apply themes .it always say "themes corrupted" how can i fixed it.
i dont know how to format my 6300 phone
please help me with that
why format my 6300 pls tell me
how to format nokia 6300
unable to format
nokia 6300 phone gor loked with security code
am attacked by a virus that keeps corrupting my files. I feel hard formatting is the only way. pliz help....ASAP.
same problem
how to format?
i have a nokia 6300 and i got my phone unlocked.... the same day my phone frose so i turned it off...... when i turned it back on it said i have a password for my memory card... what should i do????
i have forget the security code?how can i break it?
hi, i lost my security code that means my sister wrongly enter wrong password from then i m not able unlock my phone so please tell me how to reset my old password
please get me soon i m waiting for your help
thank you,
i want to format my mobile 6300
i want to format th cell pone NOKIA 6300
i have nokia 6300 when ever i switch on the cell..it gets automatically switches off...i want to flash my cell...plzzzzzzzzz help me...
