My 3110c phone won't turn on anymore. Help!! I just turned it off one time and when I try to turn it back on, It won't turn on completely anymore. It will still show the nokia screen and then a white screen will flash 3 times and then the phone will turn off. Could anyone help me please?..
It happens sometimes that a phone does not turn on. This is due to both mechanical or electrical problems. Try the following:
- open the phone cover and detach the battery - after 15 seconds attach it back - try turning on the device
If it does not work repeat the above procedure at least 10 times. If it turns on the suggestion is to not turn it off anymore if the procedure was tried more than 3 times.
try to leave it without any power for a few minutes..remove the battery ..and after that plug it back and power it up ...If the code is asked just enter teh correct code and see if it works ..If it is a pin code..it may being asking for the puk code..and that one you have to get it from the provider ..but if it is just a security one ..from the phones feature it may work ...removing the battery makes it forget the date and time ..and this will make it let you insert the code again ..Usually when you insert he wrong code too many times it will be locked for a while ...
help me to format my nokia 3110c.... the problem is i can turn on my phone but in several minutes...... the screen become white and and shutdown automaticly......please help me.........
