Question about Samsung LN-S4692D 46 in. LCD HDTV
Lns4692d no picture
I have a samsung LCD lns4692d, and the picture no longer comes up on the screen, i can go through multiple sources get sound but no picture. Usually when you change sources there will be a source name on the screen which does not show up anymore. The LCD is backlight, and you can see when you change channels or sources it flashes, but never a picture. Based on other comments I have taken the back panel of the lcd tv, everyone else who had this issues states this to be a issue with tcon (timing controll board) /lcd controller board. Is this the same board where the audio video sources, antennae and cable plug into?
BN94-00963B ASSY PCB MAIN-SPZ LNS4692WX/XAA,AM LCD
  • kennethkocan Feb 12, 2009
    I have the same problem with mine, what was the solution?
  • 113 Answers
No it is the little board underneath the metal container at the top middle of the panel..the very top.
-Josh
Posted on Mar 14, 2008
6ya staff
SOURCE:
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
Samsung TV will not turn on.
OK if it is LCD your and have sounds but no picture you possibly have faulty inverter board that need to be replace
Dec 03, 2012 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung 46 inch lcd no picture only sound
Could be backlight or the Invertor. While the sound is operating shine a flashlight into the screen and see if you can see the picture or not then let me know and I will assist you. But I will also need the model number of the set.
Feb 08, 2012 | Samsung Televison & Video
My samsung LCD LNS4692D has picture for 2 to 5 seconds only after turning it goes out. audio remains on. picture quality is good. is it the T-con?
0ne of 3 has failed:
(in order of probability):
1. Backlight inverter
2. Power Supply
3. Backlight
More specifically on #1 and #2 - capacitors either bulging, leaking, or exploded.
Please seek the expertise of an experienced TV repair technician - as they contain potentially lethal voltages that must be properly discharged before work can begin.
Thanks!
Feb 02, 2011 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung LCD -no picture/sound from any input source-Cable,DVD,PS3
Use the menu button in the front screen of your tv.Maybe your remote control need a battery.
Jul 24, 2009 | Samsung LE40B650T2 40 in. Full HD Crystal...
Samsung le40a lcd - picture quality
Hi - I have some suggestions. The following factors effect picture quality:
1. Source (because LCD TVs have much higher picture quality than traditional CRT "Tube" TVs, the worse your source material, the worse it looks on a LCD TV).
DVD and Sky/Digital TV should look excellent on this TV when connected with a good quality Scart lead (nothing too expensive, but a Oxygen Free Copper Gold lead may help) directly into one of the TV's Scart inputs (avoid using "switching" boxes for multiple equipment).
Also, bear in mind that this is a HUGE screen (40 inches I think) and will REALLY show up bad source material.
The best advice I can give is, if you have HD-ready equipment use HDMI connections for everything (ideally with an HD-uplscaling DVD player which will "improve" the quality of standard DVDs on the TV - I recommend models by Philips) and check that you are in "Movie" or "Cinema" mode on the TV.
Make sure that all of your equipment, like your Sky digibox, is set to 16:9 mode (not 4:3) aswell to preserve the true widescreen aspect ratio.
Hope that helps!
Dec 31, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
I have a 46" Samsung, model #LN-S4092D. Two weeks ago the picture stopped working. There is sound and some light coming through the rear of the television (when the back cover is off). Sears ordered a new...
If your TV has a 46 inch screen then the model must be LNS4692D not 4092D. I recently had the exact same problem with my LNS4692D after 30 months of use. It was indeed the A/S T CON board that caused the problem. I ordered a board from partstore.com and replaced it myself. The TV is now working as it should. Saved $500 to $600 by doing the work. I documented the repairs, complete with pictures in a MS Word document but I dont think I can post it here. Replacing the board was not too difficult but it should not be attempted by someone with no experience at all in these matters.
Dec 16, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
LNS4692D - TCON Board (seems there is a systemic issue)
You have to be very careful with the flat ribbon cables and be sure not to have an electro static discharge to the board while handling it but it is not that difficult of a repair. It is the board that is located at the top center of the back of the lcd panel. Depending on your problem, eg. line in picture, no picture with backlight.... it unfortunately only fixes about half of the units. The other half need lcd panels which are very expensive. hope this helps.
Mar 25, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung LN-S4692D 46 in. LCD HDTV Logo
699 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
