Motorola Mobility H700 Wireless Headset Logo
Posted on Mar 13, 2008
H700 automatically disconnects though fully charged
My bluetooth has worked perfectly for many months, then suddenly it began cutting off in the middle of calls, like it couldn't hold a charge. Now, after it has been fully charged and the light is green and everything, when I open the mic to connect with my phone as usual, the "Connected" screen shows and is immediately followed by the "Disconnected" screen. Upon opening, the light on the headset flashes blue once and but makes no further signs that it is functioning. If I hold the button down, the purple light comes on briefly, but still no change regarding it connecting to my phone. I tried deleting it's account on my phone (I have a motorola) but now I can't get the bluetooth to be recognized by my phone to reform the account. Does this just mean that my battery is dead, because the motorola website says that we shouldn't replace the battery.
  • 4 more comments
  • Anonymous Mar 14, 2008
    Exactly the same thing! Please someone have an answer. I just received mine.
  • fishdave Apr 18, 2008
    I have the same issue and what is happening is that the switch that turns on the headset is not keeping contact. If you push lightly on the microphone the unit should stay connected. I have not figured out how to fix it yet. I am sure that there is spring in the unit that has gotten weaker. It could also be a plastic clip that has worn down and is not appling enough pressure to keep the unit on. I am consdering taking it apart to see if I can fix mine.
  • studfiver Apr 22, 2008
    I have the same headset and it is brand new but the battery wont hold a charge. It will beep when on a call then drop it cause of the battery being dead. When i plug it in to charge the light is green. I have tried charging it all night and still same thing????
  • princesslj Sep 20, 2008
    I have a motorola h700. Fully charged. After talking for about 20mins it disconnects from cellphone. Call still connected to phone, but earpiece would not reconnect til next phone call. Why does this occur and how can I fix. Palm said "soft" reset of phone, but problem still continues.
  • H C Oct 12, 2008
    Once headset is charged it constatnly switch from connect to dicconnect
  • H C Oct 12, 2008
    I have the same problem. I have had my H700 for a while howerver every time fully charge it connect and disconnect constanly.
A
Anonymous
I had the same problem. It does seem to be related to the battery. The solution--in my case--was to recharge the headset until the light turned green again and then flip it open and it hooked up again.
HOW DO I PAIR MY MOTOROLLA H700 TO MY IPHONE
The H700 is a little picky when pairing.
Make sure the H700 is fully charged.
1. Leave the H700 Microphone closed and hold down the button until it turns purple. 2. Once the light is purple, open the microphone. (If it turns blue then start over. This is normal operation mode not pairing.) 3. Go into iPhone Settings>General>Bluetooth and turn Bluetooth on 4. H700 should appear on the screen. Select it. 5. If the device asks for the Device PIN, enter: "0000" 6. The two are now paired.
The H700 may leave pairing mode during the process. This is the pickiness I mentioned. If it does then just restart the process. It may take several tries or it may work on the first shot. Just be patient.
4helpful
My H700 Motorola Bluetooth does not go to pairing mode by steadily lit in purple, even after turning off the phone it is currently paired with and after I close and reopen the H700 Motorola Bluetooth ...
First off, you want to have the H700 fully charged up and it's probably good to have the phone fully charged up too. Now turn off the H700 (the ring around the talk button should not be flashing blue every few seconds) then push the talk button for about five seconds, until the ring around it displays a purple color. Immediately let go of the button and flip open the tiny microphone extension. Now it's in pairing mode and you can leave it while you fiddle with the phone to finish the process
May 11, 2010 • Cell Phones
4helpful
2answers
Changed phones want to install blue tooth h700 but it asks for a passkey. Where do I fibnd the passkey?
The passkey is 0000 (four zeros). If you need instructions do the following:
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} First off, you want to have the H700 fully charged up and it's probably good to have the PHONE fully charged up too. Now turn off the H700 (the ring around the talk button should not be flashing blue every few seconds) then push the talk button for about five seconds, until the ring around it displays a purple color. Immediately let go of the button and flip open the tiny microphone extension. Now it's in pairing mode and you can leave it while you fiddle with the PHONE.
On the PHONE, you want to push the "OK" button to get to your main tools area:
Choose Settings, then choose Connection:
Now you'll be able to pick which type of connection you want:
You want bluetooth, of course, so pick that:
Now you can specify that you want to add a new Handsfree device (even though, logically, you should go to Setup in my eyes):
Select Look For Devices, at which point the PHONE will scan for available units in the bluetooth frequency spectrum and hopefully find your H700 bluetooth headset. Assuming it does, it'll cheerily report the news:
If your PHONE doesn't find the headset, I suggest that you run the scan another time or two. Also make sure that the H700 is still showing purple, not blue or flashing blue. That should be all you need to do!
Once the PHONE has found the H700 unit, you need to actually pair them, so don't stop here. Select the H700 and you'll be asked if you want to bond the two units:
You want to say "YES", of course, at which point the PHONE will ask you for the bluetooth passkey of the H700, which, like all Motorola bluetooth headsets, is 0000. Enter it:
Choose "OK" to proceed to:
The phone has saved the pairing passkey, now it'll disconnect and search for it again in regular connection mode:
Hopefully it'll still find it, and verify the PIN:
Now, look at the H700. Notice it's no longer in the purple "pairing" mode but has switched to the regular slowly flashing blue mode. You're up, running. I hope this helps and Good luck!
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Please remember to vote 459e9de.jpg and leave a testimonial. Thanks.
5helpful
4answers
I can't pair my Motorola H700 to my Blackberry curve.
http://khaoohs.wordpress.com/2007/11/16/motorola-h700-bluetooth-blackberry-pairing/
this actually works.
Problems w/H700 bluetooth
Try taking a small needle and gently clearing out the mike hole near the end of the boom. Anything I am outside and sweating a lot mine will clog up and I have the same trouble until I clean it out and then it's fine. Do not insert the needle in very far, all you need is to clear the outside opening a bit.
3helpful
Motorola H700 Bluetooth connection problem
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H700 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
H700 is paired to phone and computer but will not connect
make sure your bluetooth function on your cell phone is on then if this doesnt work delete this device from your phone an reinstall it
2answers
Motorola H700
I say uninstall this device from the phone's bluetooth devices and reinstall it fresh
Was working fine until now.
uninstall device and try to reinstall if this doesn't work go to www.n1wireless.com about 30 bucks
2answers
H700 Headset
Is the Samsung bluetooth turned on?
Top Motorola Mobility Radio Communications Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
