Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television Logo
Posted on Apr 15, 2017
37av555d hi there. i just replaced the screen , in fact i had a 37av555d toshiba but i c ouldn t find the right board, so i found two boards for 32 ,the board are the same . but i have to do same setings for the screen in service mode, as OPT4 and OPT5 for the model and screen size, i have changed them after i switch off the tv , everything is back to the normal setings, i have been trying to change other setings there,and everithing remain saved after you switch off the ty, only both setings for the screen, and both boards are doing the same, so is nothing wrong wich the board, i really need help. thanks . dani
5 Related Answers
Anonymous
  • 4402 Answers
  • Posted on Feb 22, 2008
SOURCE: Toshiba Regza 32"
I would return it, sounds like the bulb died.
Anonymous
  • 52 Answers
  • Posted on Aug 26, 2008
SOURCE: Red Blinking Light
These types of problems are allways hard to diagnose.. If you were to power on the set and preform tests, you would think that everything was fine until the moment it shuts off.
Look on the main power board and see if you cant find the thyristor (thermal switch), those are the things that when heated will cause the set to power off for safety reasons.. They are normally placed where ever a large heatsink is. That may give you a location as to the problem and you can put a meter around its 2 pins with the set off and unplugged a couple of min after failure, if its short (0 ohms) thats not the problem, if its open, it triggered the event.
Second, you can run the set for a while and check the voltages and Ve, Va, VCC, Vsetup etc and compair to the markings on the plasma PDP sticker. If you see one is falling down over time (volts will be lost as heat) then you can isolate that portion of the supply.
Third and allways the best way to go about these problems is buy a thermal gun and moniter various spots for heat.
Its just vary hard to say, resistance could be off somewhere, diodes could be overheating as well as fets and caps. Thats why a good thermal gun can point you to exactly where the problem is.
Hope this info helps, but I would suspect the problem is on the main power supply itself and not the y sus and z sus boards side boards.
Anonymous
  • 5 Answers
  • Posted on Dec 30, 2008
SOURCE: Our display board was replaced now the y sustainer board needs replaced
Three suggestions:
Contact http://www.ptscorp.com/television.html. They have a selection of replacement boards or will repair it Fees are usually $50 to $125 and I have had great success with them.
Another would be to try www.shopjimmy.com and lastly do a Google search, if you know the exact part number, to find other sources for the board.
Anonymous
  • Posted on Jan 02, 2009
SOURCE: i have a toshiba 32hl67u lcd tv
I had same thing happen recently on same model. Turned it on one night, light came on in screen, briefly saw info bar at top, then nothing. Cannot get picture, volume or menu. Each time I turn off and turn on the same thing.
Any solution to this appreciated.
Anonymous
  • 36 Answers
  • Posted on Aug 03, 2009
SOURCE: Connecting Compaq Presario CQ40 to LCD tv Toshiba REGZA '32'
Check your resolution output from laptop it maybe set to high for the TV to handle, also go to the Display Properties and ensure that the second monitor out is enable. Good luck!!
37av555d black screen
Replace the inverter board 6632L-0506A. In all fairness I'd check that it receives 24V first, but usually it's the inverter and not the power board. I believe we carry those...I might be wrong. I know we replaced some of them in the past years.
I have a Toshiba Regza LCD 32"-model #32HL67. I can turn on the tv and see the screen just fine with a clear picture and hear audio too, but after about 2 seconds the screen will go black but i can...
Eight out of 10 times this would actually be the inverter board where usually a transformer has gone bad. It's not worth fixing the transformer (although often possible) - just replace the inverter itself.
if you can't find many inverters online, e.g. on eBay, that's a good sign you're on the right track with the diagnose.
The 9th time it would be the power board, usually due to bad filter capacitors at the exit; those are usually seen with ***** eye on the power board itself.
The 10th time it could be something else such as the main board or the T-Con; in fact, probably less often that that.
Hope this helps. If it does please rate it accordingly. We enjoy positive feedback :-)
www.coppelltvrepair.com
Could please help me how to fix Toshiba Regza 32LV67U 32 in. HDTV LCD TV TV/DVD Combo Blank screen
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
If i turned ON , sometimes , tv screen and image does not appear but sound is on ! That problem appear not all the time i used TV and if i turned off and on a few times - that inconvenience is dissapear...
Check for dry soldering, bulged capacitor, but if otherwise Problem is in either power supply or the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
Thanks and take care...
32'' Toshiba Regza difficuut to switch on from plug & standby
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
2helpful
I have a 2008 Toshiba 32AV500U flat-screen television. Last week when I turned it on in the morning the power light came on but I have no picture or sound. I have been looking for a schematic or blog...
i work at cort furniture in kalamazoo mi. as an electronic tech.my co. has about 143 of these model ty'sthey rent. i have ran across about ten of these that don't come on. the most common failure is the right inverter board and sometimes it is the main signal board.they have no replacements for these but have to be sent in to a repair co.to be repaired.
Toshiba REGZA 37AV555D smashed screen
Yes the screens can be replaced and if you're half decent with a screw driver (and have the patience of a monk) it's probably worth attempting yourself.
Ball park figure for a new screen is around £150 but I recommend you get on eBay and buy either a used screen or smashed up laptop and take the screen off that. It should work out a much cheaper repair.
Settings
Have to reset or it is reset to factory settings?
Has anyone been playing with this TV, i.e. repairing it, replacing boards etc?
I believe - do not know it for a fact - that Samsung has this protection in palce which identifies the boards in a TV and once you switch a board the TV needs to go through a service re-administration to remember its current configuration.
There's no explanation of why would a TV need to do that other than to restrict users to Samsung service centers only.
Again I do not know this for a fact, but I have seen other Samsung TVs that do exactly the same and they start doing it upon replacing boards on them. It's a simple logic.
2answers
The left side of the screen is black right side is fine
Chances are you have a LCD Panel that has failed.
I would call Toshiba at 1800-631-3811 and see if they could assist you in the repair cost. It would require a Service Facility that is Toshiba authorized
to confirm the symptom.
I hope this helps,
Skyassoc
3answers
New Toshiba 32'' - sound gone funny
on your remote control click menue and than select sound and go from there
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
