Bulova Watch Logo
Posted on Mar 26, 2010
Montres carlo 3042f doesnt play sound
My montres carlo solar rubber wrist watch 3042f is not playing a sound when the set alarm time is met.
Anonymous
Level 1:
New Friend:
  • Contributor 51 Answers
  • Posted on Mar 26, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
51
Questions
0
Helped
16807
Points
79
Sounds like you have turned function off you need to go into your menu for alarm and alter setting..if you not got the instructions you can get them of the world wide web.
2answers
Montres Carlo Watch
ok.. let's see what i can get... do you want another copy of the manual..?
Jun 27, 2008 • Watches
3helpful
Looking for instructions for a Seiko digital alarm chronograph solar powered back has 8n1913 the 8 could be a B. Thanks
seiko chronograph set the alarm etc pull the crown out 2 clicks.... set the alarm the same as your current time on your watch..... push the crown in 2 clicks..... than pull the crown out 1 click ..... set the alarm at the desired time with the lower button..... than push the crown in 1 click .... the alarm is ON
or go to this address http://caliber.seikowatches.com/ select the desired language than - alarm chronograph and play the alarm option on your right
May 14, 2010 • Watches
My watch is solar powered and keeps flashing low....
Is your watch covered for most of the time that it is being worn?( by sleeves perhaps?).
There must be a lower limit of exposure time required to keep the battery charged (so that it can run overnight), perhaps this requirement is not being met.
1helpful
How do I turn the alarm off on my casio g shock atomic solar wrist watch ?
Don't have this one but the procedure is similar for any Casio watch. procedure has many steps, so would recommend consulting the manual for your particular watch.
for a manual go to
http://www.casiowatchrepair.com/
click on the Need a Manual
Once you have it you can search for how to do almost anything
hope this helps
Setting Date & Day
Two clicks to the dial on the right. First click adjusts the day of the month. To change the day of the week pull out to second click and go forward or backward in 'time' and week will follow.
Apr 11, 2009 • Watches
Watch
press the udjust button up to 3 second ,when the digit is blinking press the mode button to select the digit that you want to set and go set the time use the two another button on left side after set the time press the udjust button onece and the time back to normal,
Montres Carlo Watch
my response was on the other thread, i will post there again..
Montres Carlo Watch
okay.. please wait..
what exactly the model# of the watch..
thanks
micro
5helpful
Need operating manual to set time and date
Just posting a solution to remove this from unsolved problems list. thanks and good luck.
Jun 03, 2008 • Watches
Top Bulova Watches Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Bulova Watch Expert? Answer questions, earn points and help others
