Try running up this motor when its not installed on the compressor,, if it still blows the trips the motor is faulty,, if it runs ok, but hums when reconted to the compressor the compressor if far to tight for the motor to turn the compressor,,,you can not reset the points in a breaker trip they trip at a set curent if the motor is pulling more amps than the trip is set for it will trip the trip to turn off the curent, the motor will pull far more amps than it should if its over loaded thats why its humming its trying to spin up it but cant so it just keeps pulling more and more amps till the trip cuts out
