From the menu screen i put the game disc in and the console spits it back out for a second then pulls it back in for about 5 seconds then spits it out completely.
kproduckt1-
Usually when you put a game into the PS3 console, it should automatically go to it. If not, put the game in, and on the menu screen go to the little icon that looks like the ps3 controller. Go all the way down to the bottom under this controller and it should show a picture of a game disc. Click on that and it should go right to your game.
http://www.gadgetell.com/images/2006/11/ps3_menu.jpg
On that picture, it's the icon second to last on there.
Hope it works out!
There's either something jammed inside of the Wii's DVD Drive, or a part on the inside of the DVD drive is broken. All drives have a sensor on the inside to let it know that a disc is fully loaded and seated. If the sensor isn't engaged within a few seconds, it will spit the disc back out.
You can find a new DVD drive at the following website:
clean the whole system not just the lens it probley is to dusty in the system. you can also try to remove the power source from the back of the system not the wall wait a min or 2 plug it back in turn it on with out the disc in it and go to the load screen where it says start put the disc in and click start. but i suggest you take it in for a cleaning at a small local game store they usuall dont charge if they dont have to do anything but dust it out. if that still fails then you most likly need a new cd drive.
When the ps3 is on standby, press and hold the power button for about 5 seconds. This runs the optimal screen settings page and should auto select the best setting for the cables fitted. hope this helps
Your disc is stuck in Wii Console, It needs to eject manually. You might check out Wii Fix Guide,
that gives step by step information on Dis-Assembling with screenshots,
even a novice can fix the disc eject problem with the help of this DIY
Guide. It also gives information on fixing many Wii Related Problems,
so its a kind of Wii Problems Reference Fix Guide
