ESQ Swiss Muse 07101116 Watch Logo
Posted on Mar 25, 2010
Stop running - ESQ Swiss Muse 07101116 Watch
Anonymous
Level 1:
New Friend:
  • Contributor 51 Answers
  • Posted on Mar 26, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
51
Questions
0
Helped
16807
Points
79
Is it battery..this will need replacing, if its automatic you need to wear it for about 7hrs to put in a reserve power of about 40hrs or if its hand wound wind it buy turning crown about 20 times..need a little more imfo....or is crown out on side push it back in to case side..
I have a 1992 Rolex DAteJust- it runs great for several weeks .. of everyday use, and then it will stop for no apparent reason. After I shake it a few times.. it runs again.. but it seems that it...
Nail on the head. Take it to a good repair/service shop that does Rolex service. Know this, it wont be cheap. But you will get the watch back in great condition and it will run perfect.
1helpful
2answers
My WAF2110 will ocassionally lose about 20 mins for no reason,also does this watch have an internal battery.
Automatic watches are spring driven and therefore do not have a battery.
Automatic watches thrive on being used and if you do not wear them sufficiently, they will run down and stop (or perhaps they run slowly before stopping).
Your watch should run for 38 hours before stopping.
Have a date just that stops 12 hours after wearing. What is the standard length of time it should run after wearing.
The running ime for a self einding watch (which I presume tha yours is) varies from maker to maker and model to model.
I explored their web site but was unable to find anything useful about running time.
Most other types run for a time in the range 36-72 hours and 12 hours seems rather mean as it does not allow much more than sleeping time before it stops.
I suggest that you approach the supplier and discuss it with them.
1helpful
Do Carrera automatic watch need a battery to run? because it stop me alot that why it just run for a few mins and stop forever until i move again
Automatic watches are mechanical (spring driven) and they are wound by the gentle swinging of the arm as you walk.
If yours has stopped, then it needs to re-wound by swinging it side to side (keeping the watch face level).
You will need to do this for some time (as many as 300 times, according to one maker).
When fully would the watch should run for about 3 days if not worn.
These watches thrive on use!
2-yr old ESQ Model 07301076 stopped running
you can find an exper in the local shop where you buy the product and they will give you specific service
for your questions about your product.
In addition, i like to play world of warcraft. there is a reliable website for
all players to get age of conan gold with the lowest price wihit in
10 minutes' fast delivery and you also can enjoy first class service
for your login.
Ebel sportwave chrongraph
It;s probably a difective movement mechinism.
Ed
NC Electronic
Mills, Wyoming
3answers
Rolex runs down
sounds like you need a new watchmaker, Your watch is designed to be worn 16 hours a day an rested for 8 while you sleep and this should keep it running. there are several different mainsprings that can be installed depending on the age and your activity level. I would be happy to take a look at it for you.
Donald McPherson
Certified Watchmaker AWCI
www.finewatchmaking.com
Watch stops intermittently.
Make sure the dial that is used to set your watch is snug against the frame of the watch. Sometimes when people reset the time on their watches they don't push the dial all the way back in which will cause it to stop. If it is an intermitten problem it may be close but not all the way in. Some watches continue to run when they are being set; whereas, some stop when the dial is pulled to reset them.
Top ESQ Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an ESQ Watch Expert? Answer questions, earn points and help others
