Hello,i guess the messages on the line one is kind of filled up,so all you need to do is just to make sure you delete all the messages you have on the line 1.after you have done this i believe the sound will go off.and if these problem should persist after you have done this,i will advise you contact your service provider to lay the complain to them and i strongly believe the problem will be solved.
thanks,you are highly appreciated.
Hello,i will suggest you contact your service provider to complain this issue to them.since you said it does not pop out the dialling tone sound.or you better check if any of the keys are not forcely pressed down.
thanks,you are highly welcomed.
hello,i will advise you contact any of your friends to assist you to contact the service provider from his/her cellular phone.or you probably visit your service provider.
thanks,take care.
This did not help. I can't use line 1 to call or delete messages or receive messages. The line sounds open when the receiver is picked up, which means there is no dial tone. This is not a cell phone it is a office phone per the information above. Try again.
