Question about Nikon D60 Digital Camera
Nikon d60 When I try to take a picture with the
Nikon d60 When I try to take a picture with the lens set on auto the lens just rotates trying to find the object. When I turn it to manual, it takes a pic, but is mainly white. I tried cleaning it and locking the mirror and unlocking it with no luck. Any suggestions????
  • 132 Answers
That is a problem that has to do with the Flash...make sure your flash settings are not turned on. If the flash can't find an image...it rotates and usually never finds the image. It's reading in a Flash mode.
Posted on Mar 26, 2010
SOURCE:
There must be something simple I am doing wrong. On a D700 body, I can't seem to trip the shutter in any aperture other than f16.
I have a Nikon D60, and it has numerous settings, including aperture and shutter priority, and others. It sounds like you have have it set in aperture mode, set for f/16. First try taking a picture in dimmer light, where it's not so bright. That should cause the shutter to open longer. The camera will adjust the shutter speed to take the best picture at f/16 if it's set for that.To adjust it to something other than f/16, on my camera, you use the thumb wheel on the back of the camera. Try changing that if it has a thumb wheel.
Next try it in Auto mode by rotating the dial on the top of the camera to the green setting and see if you get a batter picture.
If all else fails, consult the camera manual, if you have one.
Jul 13, 2011 | Nikon 85/1.4 AFD Nikkor Lens
I have a Nikon D60 and I just started having an issue with it. When I take pictures indoors on auto (or any setting) the pics turn out fine. The issue is when I take it outdoors. Every picture is...
A good solution is from the main overview screen, press the button in the very bottom left-hand corner. From there, you can manually adjust the exposure of all pictures taken. Try turning it down until the pictures look normal. Another thing to try is to lower the ISO, which can also be controlled from the same menu, or from the settings in the camera. The max is 1600, with the lowest being 100.
May 01, 2011 | Nikon D60 Digital Camera
Our D60 used to take great pictures. I only use it on Auto since most are pics of people or still objects and really I don't know to use all the settings. All of a sudden, the shutter speed is now very...
The pictures are blurry due to camera shake, which in itself is caused by the slow shutter speed. Try using shake reduction setting. To increase the shutter speed, raise the ISO rating.
Sep 06, 2017 | Nikon D60 Digital Camera
I have a Nikon D60 and have just bought a 50mm AF 1.8 D lens but find I can only use the aperture setting at 22. Is that right ?? why can't I use the other aperture settings ??
The D60 camera sets and triggers the aperture that you have selected (or the camera has selected if in auto mode) and sets the aperture as you take the picture. Moving the aperture ring on the lens will not work, in fact once you move it from the f22 position the camera will stop or possible show and error. on my older Nikon AF lenses there is a small lock to lock the aperture ring in the lowest position when mounted on a digital camera, it is found near the f2.8 side of the aperture ring. when you want to set the apertures manually, you put the camera in aperture or manual mode and set the aperture you want by moving the the rotating wheel on the grip part of the camera. the aperture you select will show in the window, you do not have to move the ring on the lens,it must remain the f22(highest numerical) position.
Oct 24, 2010 | Nikon Normal AF Nikkor 50mm f/1.8D...
My camera does not autofocus
Check if you have any of following issues
1. Lens is not AF or AF-S
2. Try flicking the lens switch from A to M and back to A again, might solve any contact issues
3. In the menu system also you can navigate to select the manual or auto focussing. if this got set to 'Manual' mode by mistake the camera will not autofocus even if the lens switch is in Auto mode.
Oct 03, 2009 | Nikon D60 Digital Camera
Nikon D60 is taking very dark pictures!!
elis - did you ever solve this problem? the same thing is happening with my d60 and i don't know what to do!
Aug 14, 2009 | Nikon D60 Digital Camera with 18-55mm +...
I have a Nikon D60 and when I take a picture, there is no image. Just a white picture. Can someone please help.
Your exposure is set way too high maybe?,
If you are using the manual function then turn the round slider located right beside the ae-l and af-l button to the right until picture sorts itself out.
Or use the twist function settings ontop of the camera and set it to AUTO.
If neither of these works then try going into the menu and selecting reset, do not worry this will not delete your pictures, then then try it out.
Hope it works and you can get back to taking some good pictures!
Jul 04, 2009 | Nikon D60 Digital Camera
Nikon D60 is suddenly taking very dark pictures
I have had "dark pictures" from each of my Nikon DSLR (D70, D80, D200, D300) cameras usually when taking pictures from a tripod and/or the self timer. Situations where you take your eye away from the viewfinder which allows stray light to enter thru the viewfinder and throw the auto exposure way off. Not sure if this is what is happening to you.
Jun 22, 2009 | Nikon D60 Digital Camera with 18-55mm +...
NIkon D60 - blury lens
for the close up photo u have to use micro or close lens set
Apr 25, 2009 | Nikon D70s Digital Camera
Lens for Nikon D60
I will try to help you, but please understand that my experience is with Nikon film cameras. Assuming that the D60 works in a manner similar to a Nikon 35 mm body and that Sigma macro lens work like Nikon macro lens, you should be able to determine the usable subject to lens distance by experimentation. First, make sure the lens is in the macro mode. To do this you must set the auto-focus mode control to the manual focus mode (see your manual). On Nikon lenses, you must first set the focus ring to infinity, then move slider switch, which has two positions marked; "normal" and "macro., to the macro position. You should now be able to rotate the focus ring to the macro range. Use the zoom ring to zoom in and out and focus with the focus ring. The the range over which the lens to subject to lens distance will yield an in focus image will be rather limited and in the range of an inch or so to 6 or 8 inches.
Dec 09, 2008 | Cameras
Nikon D60 Digital Camera Logo
210 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
