GE Energy Star WCVH6260F Front Load Washer Logo
Posted on Mar 12, 2008
GE Energy Star WCVH6260F Front Load Washer: door locking problem
GE Energy Star WCVH6260F Front Load Washer. you set on any cycle it locks door does entrapment cycle as explained manual after 2-3 minutes says door locked and start/pause button is blinking. when you again say start it does that initiasl check cycle and again stops with start/pause button blinking . does not go to actual wash cycle
  • 1 more comment
  • Anonymous Mar 19, 2014
    DOOR LOCK LIGHT FLASHES AND MACHINE STOPS
  • Anonymous Mar 21, 2014
    start light blinks when i try to start wash cycle but the cycle doesnt start
    wont start, when start button pressed machine just beeps 2-3 times. door does not lock. nothing happens
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Oct 31, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
5264
Points
15
Http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 16, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
3559
Points
How do i fix this problem
GE Energy Star WCVH6260F Front Load Washer washer wont fill with water and does the error beeping after about a minute and continually says door is locked when it isn't
Sounds like the door sensor has become faulty. Unfortunately this is only a vague symptom,of the actual Root cause Are there any other error codes?.
Door wont lock on front loader
It is possible that you have a bad door lock assembly, I would check the wiring harness connector to door lock for proper fit
2helpful
My washer will not start. I press the start/pause button and it just beeps twice and does not lock door or start wash. ge adora model wcvh6260
clean the drain filter located behind the front lower panell, its prob. holding excess h2o and wont let the water fill cycle activate. this happened to mine.
Washer won't drain
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
1helpful
3answers
GE Energy Star WBVH5200 Front Load Washer
My GE Energy Star Front Load Washer is reading 5.9 instead of 59 minutes and not washing clothes. We cleaned the filter and still no luck. Please help.
Front load Washer
You have to clean-out your inlet hoses; the hose/s external of machine, the screens. You may not be getting sufficient water.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean(ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Top GE Washing Machines Experts
Virgil Watts
Steve Sweetleaf
Steve Sweetleaf
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
