Do you have files in the queue? What is the printer status in Devices and Printers area?
Since this is a USB printer, my usual trouble-shooting starts with checking the USB connectivity. If you are using a hub, try connecting directly to the printer. Change to a new USB cable and try a different port. Check if a known working device will work in the port. Make sure the ports are not disabled for power-savings or security (power savings is adjusted as an advanced option in the same area as setting the Screen Saver, Security shut downs are in the Device Manager).
Frequently, you can reset the printer by unplugging the USB cable from both the computer and the printer and pulling the power cord for a minute. If the items in the print queue cannot be deleted from the queue, use the Command Prompt (run as administrator by a right click - Start, All Programs, Accessories) to empty the queue. Once in the command prompt, type "net stop spooler" without the quotes and then hit <enter>. Then type "net start spooler" (again without the quotes) and hit <enter>. Once the commands have been processed, reboot the computer.
I hope this helps.
