I am unable to save the gprs settings send by the service providers in my Nokia 5200 mobile phone. When the operator send me the settings ,,the phone prompts "only 70 sets allowed setting discarded" during saving the settings. so please help me to solve this problem.
I was also facing this problem try this site they have given step by step tutorial how to solve this
http://www.meramobi.info/2010/08/only-70-sets-allowed-problem-solved.html
if you have any problem regarding this post comment on meramobi.info site they will help
hit thanks if u like
SOURCE: IN NOKIA 6300 GPRS SETTING
My solution is required another nokia 6300 that no this problem and need program NOKIA PC SUITE.
first you should backup setting from this phone via nokia pc suite
after connect your phone 6300 that have config problem to computer
then restore the setting from backup to your phone after restart your phone and enjoy.
SOURCE: setting discarded
Dear sir
please i wanted to configure gprs on my nokia 5200 but i cant whenever i enter in to configuration setting the phone will show not enogh memory
ineed your help
SOURCE: IN NOKIA 5200 GPRS SETTING NOT SAVE DISPLAY SHOWS
Follow the following steps to save your configuration settings.
1: Download & install OxyCube.
2: Connect your phone with USB cable. (USB Cable drivers must be installed)
3: Run OxyCube.
4: Select C: (Your phone memory).
5: In folders tree select Omadm Folder.
6: There will be 70 Numbered folders under Omadm.
7: Delete all folders accept first 5 & the folder named PRECFG.
8: Disconnect your phone.
9: Reboot your phone.
10: Either request you provider to send you settings. or insert it manually.
11: This time the settings will save normally.
Waiting for your positive comments.
SOURCE: IN NOKIA 6300 GPRS SETTING NOT SAVE DISPLAY SHOWS ONLY 70 SET ALL
3: Run OxyCube.
