Frigidaire FGF337BC Gas Kitchen Range Logo
Posted on Mar 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Smell gas in front of the stove every now and then
Smell gas in front of the stove, doesnt happen very often the gas smell. I checked the connections and they are all good with no gas leak on the connections behind the stove,
raysaw
Level 2:
Sergeant:
  • Expert 267 Answers
  • Posted on Mar 25, 2010
raysaw
Expert
Level 2:
Sergeant:
Answers
267
Questions
Helped
96625
Points
732
Put some bubble blowing solution on suspect areas, if there is a leak it will blow bubbles, no joke...
How do I install a whirlpool top gas stove?
You need a gas connection .then flex tube channel locks or a pipe wrench and some Teflon tape. Connection should have shut off valve.should be shut off. Put Teflon tape on threads then connect the connectors. Open valve.check your work twice listen and use your nose for a foul smell.
1helpful
Smell Propane
I have the same issue when the tank starts to get low and nearing the time too refill. Just thought I would share that in case that is the issue. I also redid all my connections the first time it happened.
I have an ES340 gas self cleaning oven. I smell gas when I open the oven door. I checked all the connections in the back and the ones behind the back panel, and none are leaking. Are there connections...
Hello tds. It is not uncommon to smell gas when you open an oven door. That said, if the amount of gas you smell is stronger than it used to be call your gas company. They will send out a technician, free of charge, to check your stove. Joe
Thanks for choosing Fixya!
2helpful
Gas stove When I turn on the oven, I smell gas,
This is more than likely the igniter to be sure you will need to do an amp draw on the igniter. To do this watch the video on troubleshooting a gas oven at www.appliancehelponline.com/servicemanual.html
Gas smell during cooking cycle - Magic Chef oven
turn off the stove and call the gas company. They will come out for free and check things out. It's dangerous to be there when you're smelling gas. If you want to look into it yourself, use a soapy solution in a spray bottle and spray the gas valve and the gas line all the way from the valve to where it connects into the stove.
4helpful
2answers
Bad smell coming from stove
Look In broiler compartment and check for signs of mice
Oven over heats/gas smell
Hi the fact that you smell gas near the floor suggests you do indeed have a gas leak, propane is heavier than air to will fall to the floor.
you really need to get the gas company to check
2helpful
3answers
Oven gas
For safety purposes call gas technician to check your gas pipe. If stove turn off supposed not to smell gas.
Gas oven clicks but doesnt ignite
Not getting gas so check gas outlet in the bottom of the oven for clogs , if not clogged the thermostat is bad
Jul 22, 2017 • Ovens
Top Frigidaire Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
