Overheating / faulty power supply / spyware has got into it.
Only two most possible hardware that can cause intermittently reboot your computer, the video driver or memory. your first step to eliminate this problem is try to right click my computer then properties then click the device manager tab and double click the display adapters and then you can see the video card brand and model then right click it and click update driver using internet or online and then follow screen instruction and after installation reboot your pc and i think it works. your second step is to turn off your pc and unplug the power cable and open the casing cover of your pc and find the memory and removed from the slot of motherboard and clean the contact surface with rubber preferably pencil eraser dont touch the surface with your hand it can damaged the memory, after cleaning install back to its designated slot then fixed the casing and try to power the pc and done.
