I have put the brewing unit into pieces, cleaned it, reassembled and it works. However, before cleaning as well as now the machine is leaking water from bottom. What to do?
The connectors on capresso machines are very tricky.
take it a part again, and make sure all the rings and pressing clamps are in the right place. Also take a good look and "IN" on your hot water tank, and the pressure relief valve in back of machine
I have solved a leak doing as suggested by hhmartins. There was noticeable white scale around a couple of connections and these were cleaned up.
Could there be a blockage? The pressure relief valve (small round thing) was easily removed and cleaned.
(I have posted my own puzzle about whether I've reassembled the brewing unit properly)
Thanks for the answer, but after a closer look into the machine, running it without covers, the heating unit seems to be the trouble, water dripping from beneath. I intend to talk to a local service, probably the heating unit needs to be replaced.
