HI there error code E:61:10 means
E:61:10
Zoom operations fault Inspect the lens block zoom reset sensor
Hope you understand. Thanks & waiting for your feedback.
Solve at home. You can try these.
Gave it a few gentle but firm whacks with 2 fingers after that i hope your problem will solve. Thanks agan.
where to give the whack?
I gave the whack... The error message disappeared but it is still blurred.Zoom is also working.
My Sony CCD-TRV228E displaying Error Code E:61:10. Please advise What to do? Give your cell No. My cell No. 9372683158
SOURCE: Error E:61:10
I suspect an issue with the CCD and the associated image processing circuitry. Please consult a Sony Service Center to have the camcorder serviced. Thanks!
Hey friend, thank you for your post!
From my understanding you are receiving an error code of "E90" on your Frigidaire washer. I am showing that as an invalid error code. It might be a miscommunication with your control panel and I would suggest performing a reset on your washer. In order to reset the washer you would need to disconnect the power from it for roughly ten minutes. If you continue to receive an error code of "E90" I would suggest contacting a professional technician for proper diagnosis and repair. Hope this is helpful. -Matt
I need model number of your camera to provide you info about E-61-11 error code.
CCD-TRV818 is an old Hi-8 camera that does not have such error code, I'm sure it is digital camera that gives you above error code.
Thanks.
Hi 8fbre16s error code 2:431
