SOURCE: Line on Blank Pages
Clean the glass whit circular moves not strait! u have a line of dust on the scanner glass.
SOURCE: when i scan a letter 2 page is scanned:letter and blank page
You may be set for front & back (duplex) scanning. Change the setting for front only or simplex. This could be done with check/uncheck boxes, a drop-down menu, or a keyboard shortcut. I believe the standard Kodak settings are via check boxes.
This model is also capable of putting out color & bitonal (black&white) images simultaniously. If that's the case the pages should be separate image files. Uncheck either color or bitonal depending on which you want.
To delete a page manually, select the page break at the end of the page, and then press DELETE.
To delete a blank page at the end of the document, select the page break or any paragraph markers at the end of the document, and then press DELETE.
