The onida split AC is not cooling the room inspite of decreasing the temp . I think the filters are clogged. how to clean the filters in split airconditioners
Re: how to clean the filters in split airconditioners
Check on top of the indoor unit. On some models, the filter will slide out from there without having to open the cabinet. On others you will need to pull on the top front and the panel will swing down (it will be hinged) and the filter will be behind that panel.
To get proper cool, keep the tips as follows: 1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure. Thanks. Helpful?
To get proper cool, keep the tips as follows: 1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Check indoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3 degrees less than room temp.6.Check compressor is working with correct pressure.
