I have got a trouble with my HP g60 Laptop battery, it is not working and i could not charge it with my HP g60 laptop Charger. where is the problem? i will be glad if you fix it.
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all.
OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time.
If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Testimonial: "great"
First ensure yourself that your charger is ok. if ok then change your battery. for using battery many days its stability decoy day by day. so you need to change your laptop battery. Caution: before you bought battery please buy the same brand battery and amphare. i mean hp g60 battery. thanks
Hai,
i think the problem in battery so try to get new battery and follow the tips to prolong u r battery life through nbbatt blog
Time to change the battery for your laptop. you can get a quality HP G60 Laptop battery here
Testimonial: "great, thank you"
It is time to replace the battery. Simple and easy to do it. Hp G60 laptop battery 6cell or 12cell
