Question about Puma Flow Digital Watch PU90005A0298H37
HOW DO YOU SET THE TIME ON THIS WATCH
WE DID NOT GET A MANUAL WITH THIS WATCH. HOW DO YOU SET THE CORRECT TIME
  • 8,197 Answers
May I get the make and model # of the watch to help you more.
Posted on Mar 24, 2010
SOURCE:
How to set the day of the week
here is your manual (I think)
http://cdn.invictawatch.com/invictawatch/website2014/webroot//uploads/manuals/2-8040n-pdf
If not, their site is pretty good.
http://invictawatch.com/service/view-the-instruction-manuals
nice video but as good as a chocolate teapot!
https://youtu.be/iv0aXQNH4yY
anyway, here is your info
Invicta Watch Setting Instructions By Ashley Brown eHow Contributor Found This Helpful A watch is only useful if it displays the correct time. Over time, your watch may display the incorrect time as the battery wears down. After installing a new battery, you will also need to reset the time. All Invicta watches have similar instructions for setting the time. Setting the time does not require any tools or equipment.
Other People Are Reading
Watches with Time Only
  1. Pull out the crown. The hour and minute hands will stop.
  2. Turn the crown until the hour and minute hands are positioned on the correct time.
  3. Push in the crown to start the watch.
Watches with Time and Date
  1. Pull out the crown to the first position. The crown can be pulled out to two different positions. Pull gently once to reach the first position.
  2. Turn the crown until it reaches the correct numerical date.
  3. Pull out the crown to the second position.
  4. Turn the crown until the hour and minute hands correspond to the correct time.
  5. Push in the crown twice. It should now be resting firmly against the watch, in its original position.
Watches with Time, Day and Date
  2. Turn the crown to reach the correct day.
  3. Turn the crown clockwise to reach the correct date.
  4. Pull out the crown again to the second position.
  5. Turn the crown until the hour and minute hands display the correct time.
  6. Push in the crown twice so it rests against the watch. The crown should be back in its original position.
Read more : http://www.ehow.com/how_7352591_invicta-watch-setting-instructions.html
Sep 13, 2015 | Invicta Watches
To adjust the analog time for ga-110hc-1a
Analog time follows digital time.Correctly set your local time and analog time will come up correctly as well.If not, try to run the hands alignment procedure (H-SET) following manual instructions.
Mar 02, 2013 | Casio G-Shock GW500A-1V Wrist Watch
My On Time Atomic watch was shipped 1 hour ahead. How do I get it on the correct time?
You need to set the correct timezone. Your watch doesn't know where it is geographically so you need to set it manually.
May 22, 2011 | Watches
I have an OCW-M 800. I have downloaded the manual from mfg. website and cannot seem to get it to set the time for EST correctly. THis watch cost me over $500.00 and is so complicated that I fear I have...
I am not American, so I am not familiar with the definition of "EST" or which of the four "city" settings is correct for you.
Having read the instructions I see that for America you have to select "USA" first and then the appropriate city, have you done this?. The list of four options covers 4 time zones, so you should be able to get the correct time for your area.
When I bought an atomic watch recently, I had to leave it overnight to catch the timekeeping signals. I see that you posted your question only 14 hours ago. How long have you had it. GIve your watch a day or so for it to latch on to the correct time.
Check that the "autoreceive" is "on".
Check that the daylight saving time (DST) is correctly set. The manuals indicate that some areas may not be using it?
Keep trying - it is nice to have a watch that is always correct!
Oct 04, 2010 | Casio OC500 Oceanus watch
My son seems to have set his Casio Wave Ceptor wv 58u to the incorrect time ..god knows how !!..any Idea How we correct it !
You need to manually adjust or set the hands to the home position as they are not where the watch thinks they should be. This can happen when you bring your watch close to a strong magnetic field. Look in the manual to do this. Afterwards your watch should set to the correct time.
P.S. – I would greatly appreciate a FixYa! rating if the solution I provided fixed or helped you resolve your problem. thanks
Aug 17, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
I have lost the instructions and cant set the time
Try Googling (pod)(548)(manual) without parens.
Aug 04, 2017 | Watches
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals.Rate me, please .
Mar 27, 2010 | Watches
On time atomic watch wrong time zone EXSV10+Talking+Watch I DON'T HAVE+instructions+owner+manual I need to set correct time?
The EXSV10 Atomic Talking Watch by On-Time sets itself to the official time standard of the United States government, maintaining split second accuracy. It can also literally "tell" you the time. It talks! The On-Time talking atomic watch also has daily alarm capability, and can be set to announce the time every hour.
http://world.casio.com/wat/download/en/manual/
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Feb 24, 2010 | Watches
Casio Wave Captor Watch wont set to correct time.
Apr 21, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
How do I get the wave ceptor to come on ?Casio-2688
Try Googling (casio)(2688)(manual) without parens for instructions.
May 08, 2017 | Casio Watches
Puma Flow Digital Watch PU90005A0298H37 Logo
261 people viewed this question
Top Puma Watches Experts
Arturs Kalnins
Arturs Kalnins
Tom Chichester
Are you a Puma Watch Expert? Answer questions, earn points and help others
